1st gear only "4 LOW"
Discussion in 'Technical Chat' started by Steve33fish, Sep 25, 2012.
  1. Sep 25, 2012 at 8:30 PM
    Steve33fish
    Steve33fish [OP] Well-Known Member
    Yorba Linda
    13 Tacoma 4x4 LB
    Hey was driving home from work tonight and decided to stop in the middle of the road and drive on 4 high just to make sure everthing stays lubricated. Stopped about a couple miles short from home and kicked it into 4 Low, This is the question? The trans never shifted out of 1st gear in 4 Low? Is this normal? RPM shot all the way up 5500+ before i decided to back it off. :confused:
  2. Sep 25, 2012 at 8:32 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Was the gear selector in D ?
  3. Sep 25, 2012 at 8:36 PM
    Steve33fish
    Yorba Linda
    13 Tacoma 4x4 LB
    Yes....
  4. Sep 25, 2012 at 8:37 PM
    OZ-T
    Peter North
    British Columbia
    Intetesting
    What kind of speed were you at with the rpms at 5500 ?
  5. Sep 25, 2012 at 8:44 PM
    Steve33fish
    Yorba Linda
    13 Tacoma 4x4 LB
    40ish... is this normal???
  6. Sep 25, 2012 at 8:45 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I didn't think 40mph was possible in 4low/1st gear.
  7. Sep 25, 2012 at 8:50 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I dont think so either. I do remember in my 89 toyota p/u I had it in 4lo and 5th gear and was only doing like 35. RPMs are going to climb crazy fast in 4lo. Are you sure it wasnt shifting and you just didn't notice?
  8. Sep 25, 2012 at 8:51 PM
    OZ-T
    Peter North
    British Columbia
    That is possible in D
    Maybe you didn't notice it shifting up :confused:
  9. Sep 25, 2012 at 8:53 PM
    jandrews
    '09 FourDubDee TRD OR
    It's not. He doesn't know what 4LO is.
    A750F Transmission 1st gear ratio is 3.52. 4Lo is a 2.57 ratio. Final drive is 3.73. This is assuming everything is stock. Final
    crank to wheel ratio is ~33.7 in 4Lo/1st. At 5500 engine RPM, wheel RPM is ~167. Actual speed will be dependent upon tire circumference, but assuming stock tires at ~96in circumference, that boils down to about 16032in per minute. That's roughly 15mph if you do the math.
    Edit: This is assuming the torque converter isn't providing additional reduction, which it shouldn't be once he attains constant speed.
  10. Sep 25, 2012 at 9:00 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You do realize that 4lo is a super low gear reduction, right?
    At any given road speed in any given trans gear, the engine rpms will be about 2.5 times higher than in 2hi or 4hi.
    2hi for pavement, 4hi for loose surfaces, 4lo for s-l-o-w-l-y climbing rocks and such:)
  11. Sep 26, 2012 at 11:08 AM
    Steve33fish
    Yorba Linda
    13 Tacoma 4x4 LB
    Just bought this truck a few weeks and its first time i played the 4lo, But i have driven my friends 08 and in 4lo it shifts like in 2w-4hi? The a-trac and traction light stays on my truck also. I was driving down hill as i watched my rpm reach the limits into red and the truck never shifted out of first gear. Maybe normal? i am going to call toyota coporate to find out.
  12. Sep 26, 2012 at 12:10 PM
    OZ-T
    Peter North
    British Columbia
    DAC on ?
  13. Sep 26, 2012 at 12:27 PM
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Maybe do it again and video your dash so we can see whats going on...
  14. Sep 26, 2012 at 3:20 PM
    jandrews
    Guys, there's nothing to diagnose here. If he's doing 40mph in 4lo, his truck is shifting through the full range of gears. He's just missing it.
  15. Sep 26, 2012 at 3:25 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    :rofl:.... Yes it's normal. You aren't in first gear. It shifts fast.
    Top speed in 4L is ~53MPH (gear limited).
