1st Gear Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TSSFiveSpeed, Nov 19, 2021.
  1. Nov 19, 2021 at 4:38 PM
    TSSFiveSpeed
    TSSFiveSpeed [OP] Well-Known Member
    Damion
    ar kansas
    5 speed taco pimped out
    Cold Air Intake, Shift Knob, Radio, URD Short Throw Shifter Kit, Pioneer 6 1/2 speakers, sound deadened, LED headlights, LED tails, 4 inch lowering blocks, bilstein rear shocks, Cooper A/Ts, oil catch can
    I have an 05 2.7 5 speed tacoma. Recently my 1st gear has been feeling wonky, shaking badly even when I let off the clutch slowly. I think it’s the clutch, but all the other gears feel fine. I just installed a short throw shifter kit from URD and I was wondering if that could be the case too, because ever since the install it feels like it’s in neutral when I’m in a gear. And I’ve also been wondering if it’s not getting enough fluid either, leaking out and such. Any help?
  2. Nov 19, 2021 at 5:27 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm thinking clutch chatter or maybe a loose motor or transmission mount, does it still shake after the clutch is fully engaged or only during engagement?
    TnShooter likes this.
  3. Nov 21, 2021 at 10:42 AM
    TSSFiveSpeed
    Damion
    ar kansas
    I figured out the problem, gasket was shot so it caused a bad leak, ordered new ones. All I really need to know is what kind of trans fluid it needs if you know.
  4. Nov 21, 2021 at 12:01 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not sure which gasket your talking about but the transmission takes 75w-90 gl4 or gl5 gear oil, oils that are designed for manual transmissions usually tend to provide better shifting but any 75w-90 gear oil will be fine.
    The clutch takes standard Dot 3 brake fluid.
    TnShooter and SR-71A like this.
  5. Nov 21, 2021 at 2:06 PM
    TSSFiveSpeed
    Damion
    ar kansas
    The shifter gasket when I installed the short throw shifter. Do you know how many quarts it takes? Thank you
  6. Nov 21, 2021 at 2:30 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Shows 2.7 qts
