1st gear troubles, can't figure iit out!
Discussion in 'Technical Chat' started by M60E3GUNNER, Mar 11, 2011.
  1. Mar 11, 2011 at 3:24 PM
    M60E3GUNNER
    M60E3GUNNER [OP] New Member
    Alabama
    MINE!
    6in lift, 35's, nerfbars, rollbars, KC Daylighters, Forced Air Induction
    I have a 2000 tacoma, ext cab. 3.4L v6. 4x4, that when I put it n 1st gear & start letting out on the clutch, it just "kicks" it outta gear, it only does it n 1st gear, no grinding between 1st & reverse, no other problems, I can't figure it out! Any help would b GREATLY appreciated:frusty::frusty::frusty::frusty::frusty:
  2. Mar 11, 2011 at 4:36 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    I had the exact same symptoms on a 1985 PreTaco, and it turned out to be a bad synchronizer.
  3. Mar 11, 2011 at 5:29 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    thats exactly what it is... synchros not only mesh geard but they keep the shift forks IN gear
  4. Mar 11, 2011 at 8:40 PM
    M60E3GUNNER
    Alabama
    MINE!
    O WOW! so, now, I guess, the next question is, has anybody done a write up on here for that? :ohsnap:
  5. Mar 12, 2011 at 4:14 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    i doubt it. its just easier to swap trans... like a junk yard trans.
  6. Mar 13, 2011 at 1:36 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Hey wait now. I used to think that, but, and I haven't taken one of those apart, I've replaced a couple gears and a few syncros and an input shaft or 2 and it was a snap. Big problem is figuring out what you need. Not always obvious.
    Pretty sure you won't find taking apart the transmission in the chiton's guide though. Usually says "due to the complexity... " blah blah. Nothing to it. Easy as replacing pistons. Well, in my limited experience.
    Can't hurt right?
