1st gen 18” bypasses
Discussion in 'Long Travel Suspension' started by TanTaco98, Jan 12, 2019.
  1. Jan 15, 2019 at 8:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Jon64l likes this.
  2. Jan 22, 2019 at 4:23 PM
    BrownMike
    BrownMike Well-Known Member
    San Diego
    1999 Taco 4x4
    Long Travel, 5 Spd, Supercharged 3.4
    This is where 16's sit. from the side the tubing (1.75") sits just above the bedline. Relatively stealthy/low profile. You would be looking at at least 2" higher then that depending on how you mount/measure. Mounted on the axle about a 11 o'clock position off the rear.
    LukeCC likes this.
  3. Jan 22, 2019 at 9:50 PM
    upongame619
    upongame619 Well-Known Member
    Danny
    98 Taco
    Home built Mid Travel Front and rear, need help new to this
    I am not bypass but here is my set up with 18s
    I will get some pictures soon and a detailed list of what i have.
    I am using 18" shocks st8 up and down, with E30 springs and a tundra axle on my 1st Gen. Strapped/bumped at 17.25" to save last bit of my shocks. I am probably about 2/3" above the bed, however my shocks are mounted inside more then most i've seen.
    From what i understand if i redid the whole way the shocks are mounted i could get more travel, however i'm happy where i'ma at.
  4. Jan 22, 2019 at 9:53 PM
    upongame619
    Danny
    98 Taco
  5. Jan 22, 2019 at 10:06 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    How much wider is the Tundra axle?
  6. Jan 22, 2019 at 10:17 PM
    TanTaco98
    TanTaco98 [OP] Well-Known Member
    Gavin
    Apple Valley, California
    Good info, been trying to figure out the best way to mount my shocks.
    3.5 per side I believe.
  7. Jan 23, 2019 at 7:47 AM
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    @TanTaco98
    I recommend taking your time and cycle everything multiple times. I know a lot of people say that but few take the time to do it. Cycle the leafs first and take the time to make some lower shock mounts that are low and forward of the axle housing but have enough clearance for the seal head, resi & bypass tubes @ full bump. That will drastically lower your upper eyelet mount.
    For example, I can run a tonneau cover because my whole cage sits below the bed line even with 18's.
    upongame619 likes this.
  8. Jan 23, 2019 at 7:50 AM
    TanTaco98
    Gavin
    How far Away from the seal do I wanna set my bumps at? “.5? Also your pic didn’t upload.
    Icon_Adrian[QUOTED] likes this.
  9. Jan 23, 2019 at 9:07 AM
    Icon_Adrian
    Adrian
    Riverside CA
    Pic should be there now. Thank you.
    The max would depend on the center line of your bump vs center line of the shock. If your shock and bump mount to the axle housing on the same perpendicular line you can keep that distance relatively small 3/8"-1/2" to allow for material flex and distortion.
    If your bump is inboard of the shock it may need to be more. Cycle full bump and max articulated to make sure. For example if your bump hits inward of the shock the bump may act as a fulcrum and @ articulation can cause you to bottom out metal to metal on the shock.
    Similar to if you have your bump outboard of the shock, the shock can act like a fulcrum @ full bottom and leverage the axle higher into the bump stop.
  10. Jan 23, 2019 at 8:22 PM
    TanTaco98
    Gavin
    Those are 18s in your photo??:eek: Also I’m confused what you mean by inboard and outboard of the the shock.
  11. Jan 24, 2019 at 8:07 AM
    Icon_Adrian
    Adrian
    Riverside CA
    Yes sir, 18" Travel 2.5" Triple Bypasses.
    In & Out refers to the orientation of the shock center line vs the bump stop striker location.
    Here is an example of the bump stop & shock mounted on the same perpendicular line to the axle housing. (Icon SKU : 95120)
    The yellow area is where the factory bump stop is located, our 95120 bump kit on Raptors move the bump out the match the shock centerline
    In terms of Tacoma's w/ hydo bumps
    In = Inboard of the shock. ie. When the bumps can is welded directly to the frame rail on vehicles that have the factory shock mount outside the frame like 05+ Tacoma's
    Out = Outboard of the shock. ie. Bumps cans that welded directly to the frame rail on vehicles that have the factory shock mount inside the frame like 96-04 Tacoma's
    LukeCC and Dalandser like this.
  12. Jan 24, 2019 at 8:13 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Those mounts are snazzy.
    LukeCC, upongame619 and Icon_Adrian like this.
  13. Jan 24, 2019 at 3:06 PM
    TanTaco98
    Gavin
    Awesome makes sense now. What is your shock angle?
  14. Mar 24, 2021 at 2:40 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    just stumbled upon this thread. really good stuff here for where i'm at in my build.
