1st gen 1997 tacoma lug nuts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma fire, Mar 5, 2020.
  1. May 21, 2020 at 8:08 PM
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Cause the washer just floats in there. The lug nut doesn’t really push it back
    Running Board Man likes this.
  2. May 21, 2020 at 8:18 PM
    Clearwater Bill
    Billy
    Largo Florida
    Pretty sure the washer is to increase the clamping surface of the lug to the wheel. Meaning it's not supposed to move after the lug is torqued down.
  3. May 21, 2020 at 8:20 PM
    Allex95
    allex
    Well im concerned because mine are loose but the lugnut is tight on there.
    Black97v6MT likes this.
  4. May 21, 2020 at 8:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    Correct nut for wheel? Studs too long?
    Wheels for that type nut have a flat surface that the washer fits in.
    Wheels with tapered holes uses a tapered lugnut.
    Are you using stock lugs with some aftermarket wheel per chance?
    Wheel spacers with extended studs?
  5. May 21, 2020 at 8:24 PM
    Allex95
    allex
    No there stock wheels I had acorn on them before and someone told me they weren’t suppose to be acorn so I got the correct lugnut.
  6. May 21, 2020 at 8:27 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    That means your studs are too long for the lug nuts/wheel combo you are using.
  7. May 21, 2020 at 8:36 PM
    Running Board Man
    Running Board Man Well-Known Member
    That or the wheel was fucked because it was ran with acorn lugs like what happened on my camry
    The taper deformed the flat seat the washer is supposed to seat on
  8. May 21, 2020 at 9:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    Unless someone told you incorrectly.
    Pic of wheel with one of the nuts off so the lug seat shows would be helpful
  9. May 21, 2020 at 9:07 PM
    Allex95
    allex
    i took one off and basically the lug nug cant get further in because of the acorns damage. its mushroomed in a sense.
  10. May 21, 2020 at 9:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    If the wheel is made for a flat bottomed/washered nut then the nuts you bought are too short and you are bottomed out.
    Or you have studs that are too long for some reason. Wheel spacers per chance?
    You have a dangerous situation from what you describe. Needing correction before driving again.
  11. May 21, 2020 at 9:15 PM
    Allex95
    allex
    I think its because of the acorn lugs they mushroomed the beginning of the hole so.
  12. May 21, 2020 at 9:18 PM
    Clearwater Bill
    Billy
    Largo Florida
    No clue what you are trying to say.
    All I know is you seem to have a situation that is dangerous to you and others that needs immediate attention by installing the correct parts.
    Good luck.
    ace_10 likes this.
  13. May 22, 2020 at 12:54 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just be glad I hope you don`t see winter chemicals down there.
    Some of the After market Lug nuts the chrome is so thin after one winter it is mostly gone .
    I venture all my lug nuts look far worse then yours then the way they look does not matter .
  14. May 22, 2020 at 2:31 AM
    zooma-loom
    zooma-loom Well-Known Member
    RIGHT out of sight of SCOTTSDALE, AZ
    1997 Tacoma, Ext Cab, 4x4, 3RZ, A/T, Manual locking hubs
    OEM lug nuts are made in Japan & very high quality, $6.00 each from several Toyota dealers online. The others are cheap $hit ..... "if you have a ten dollar head, you buy a ten dollar helmet"
    ace_10, Black97v6MT and GQ7227 like this.
  15. May 22, 2020 at 5:03 AM
    #35
    Running Board Man
    Im fairly certain every toyota with an alloy wheel uses the same style lug
  16. May 22, 2020 at 7:06 AM
    #36
    GQ7227
    GQ7227 mw survivor
    J A Y
    :annoyed: :angrygirl: :annoyed:
  17. May 22, 2020 at 7:54 AM
    #37
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    :burp:
  18. Sep 14, 2024 at 7:53 PM
    #38
    riddmkidd
    riddmkidd Member
    Damien
    SF Bay Area
    v6 4x4 xtracab
    Hi all,
    Reviving this thread because I thought I bought the right lug nuts but when I put one on it didn't fit flush with the wheel. Did I order the wrong ones? I have the stock steel wheels, I thought. But the lugs on it now are the acorn type. But the one with the washer doesn't even come close to the wheel even though it's tight. The reason why I was trying to replace them is because the tire shop tried to upsell me with a new set for 50.00. I said no thanks I'll do it myself. Do they even look like they need replacing?
  19. Sep 15, 2024 at 6:12 AM
    #39
    mtb_taco
    mtb_taco Well-Known Member
    2001 Tacoma
    Yes the ones you bought are the wrong style. You steel wheels do not need the shank on them. Your wheels have the correct oem lugs
    Clearwater Bill likes this.
  20. Sep 15, 2024 at 6:27 AM
    #40
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Uh. No.
