1st gen. 2.7l vs 2nd gen. 2.7l
Discussion in '4 Cylinder' started by TacoMan1911, May 9, 2013.
  1. May 9, 2013 at 11:30 AM
    TacoMan1911
    TacoMan1911 [OP] Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    Are these the same engine, or are there different specs? What does the first gen. 2.7l look like?
  2. May 9, 2013 at 1:08 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    3rzfe is 1st gen engine
    2trfe is 2nd gen
    Too many specs to list so just search them, but they are built off same design. Irreverent performance/mpg wise since the 2trfe having more hp is in a larger and heavier vehicle.
  3. May 10, 2013 at 8:18 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    One of the differences between the two engines is the current 2.7 (2TR-FE) has hydraulic valve lash adjustment, while the older 2.7 (3RZ-FE) uses shim over bucket valve adjustment.
  4. May 13, 2013 at 3:33 AM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    Another difference is that the newer 2TR-FE uses variable valve timing (VVT-i).
  5. Feb 11, 2020 at 4:58 PM
    tcervinsky
    tcervinsky Old man with a gun.
    Tim
    Williamsport, PA
    2002 Tacoma
    Bringing back an old thread to ask, so if I had access to a 2nd gen 2.7L tacoma would the engine swap into a 1st gen tacoma without much trouble (assuming I would swap all the engine wiring with it)? Is the automatic transmission in the 1st gen controlled by a separate module or is it controlled by the main engine management computer? I'm looking at a badly wrecked 2010 truck but it is a manual transmission where as I have an automatic.
