1st Gen (2001 Tacoma) - Automatic Transmission Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by jjbbing, Jul 20, 2018.
  1. Jul 20, 2018 at 10:41 AM
    jjbbing
    jjbbing [OP] Member
    Jack
    Vermont
    '01 Taco SR5 4X4 6 cyl.
    32" tires, aluminum cap, deck plate, slidders
    Starting a new thread with this issue. I've read through a lot of similar issues, but none seem to be exactly aligned with the issue I'm having.
    My 2001 3.4L Tacoma (auto trans).... About 6 months ago (in NH, cold weather) I had trouble accelerating once in D after truck sat outside work in nearly 0 degree weather all day. I reversed out of the parking spot fine, but once in D it felt like trying to get going starting a 4th gear (high revs barely barely rolling forward). Once things warmed up and I waited (~5 mins), it drove like normal, smooth and no problems. I have flushed the tranny and replaced the trans filter since. Now in the past week, 3 times when I back out of my garage (warm summer weather) and put it in D I have this same problem, rev's up barely inches forward and after a few minutes of sitting there, it will perform normally. Reversing out of garage, the truck feels perfectly fine. I also can bypass it by manually shifting to L, in which it takes off great and I can then slide into D once moving along at ~15 MPH or so...
    Any tips would be appreciated?! Been reading about solenoids, hope this isn't symptoms of needing a whole new tranny... I don't think it is brake related since I can back up perfectly well with no issues. I have a lot of driving planned for vacation next week and am trying to hedge my risks with the truck now! Thanks for any suggestions/input!
    @gearcruncher - I was tipped from another thread that you may be an expert in this field!?
  2. Jul 20, 2018 at 11:09 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Sure does sound like new tranny time to me. Be interested to see what others say.
    DawsonDestroyer likes this.
  3. Jul 21, 2018 at 1:51 PM
    gearcruncher
    Canadain bumper technician
  4. Jul 21, 2018 at 4:02 PM
    HomePC
    HomePC If it ain't broke, let's fix it anyway.
    Omaha
    2001 Toyota Tacoma Double Cab Black TRD Off Road V6 Automatic 4WD
    For comparison sake, I got 180K out my tranny before it ate itself. I'm a light driver too. Midwest. Also a 2001 3.4L. I don't complain though. That's the first major problem the truck ever had (disregarding frame rust of course).
  5. Jul 22, 2018 at 11:59 AM
    jjbbing
    jjbbing [OP] Member
    Jack
    Vermont
    @gearcruncher, I ran it for codes, but have none showing up
  6. Jul 22, 2018 at 1:11 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    My 01 4wd DC has 245k and at around 90k it had these same symptoms. Changed transmission filter/screen and fluid. Issues have never returned.
  7. Jul 22, 2018 at 1:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sounds like a shift solenoid got stuck and you either started in 2nd or 3rd. This happened on my Land cruiser from time to time, just because one solenoid stuck occasionally
    j4roe and Ritchie like this.
  8. Jul 23, 2018 at 4:48 AM
    jjbbing
    jjbbing [OP] Member
    Jack
    Vermont
    I've read that if it's a solenoid issue it would usually throw a code, is that not always the case... or if its just beginning to fail it may not have tripped a code yet? Thanks for the input!
  9. Jul 23, 2018 at 6:43 AM
    Kleenax
    Ray
    Michigan
    I just did a huge road-trip (4,500 miles), and got a 0770 code somewhere in rural Mississippi. I really didn't notice anything bad was happening (pulling a 7'x14' enclosed trailer), but I stopped & checked it out (trans solenoid issue), cleared it, and it hasn't come back in 2,500 miles (yet).
  10. Jul 23, 2018 at 8:40 AM
    Speedytech7
    If the solenoid still had the right resistance and actuated a tiny bit or eventually corrected it wouldn't throw a code. Mine never does, just will start in 2, realize it screwed up and go for 1. You can also manally put it in 1 with the stick to see if that's what's happening
    Ritchie likes this.
  11. Jul 23, 2018 at 9:21 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Am I crazy or are auto trans supposed to hold a certain gear until it reaches a certain temperature as a safety feature?
    When I drive my truck on cold days without letting it warm up, it’ll hold a certain gear and won’t shift any higher until it warms up properly.
    Running Board Man likes this.
  12. Jul 23, 2018 at 9:23 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    He said his transmission is holding in 4th gear which wouldn’t make sense - if it was just the tranny not being warmed up then it would be locked in a lower gear.
  13. Jul 23, 2018 at 9:26 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I know.
    Why would you put gear lube in an automatic transmission?
  14. Jul 23, 2018 at 9:43 AM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    Your tranny won’t shift into 4th until the water temp hits 130 since the water helps heat up the tranny fluid the same way it helps cool it.
  15. Jul 23, 2018 at 9:45 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Automatic Transmission Fluid is essentially a highly specialized compound that has several functions. It’s basically a high performance hydraulic fluid that has additives in it to prevent things such as rust, corrosion, etc. Additionally, it contains several specialized chemical compounds that protect and condition rubber seals, and dispersants and additives to allow the transmission to operate correctly.
    A manual transmission has far less moving parts, and does not require all those additives and compounds. You’d wreck your automatic transmission pretty badly if you poured standard gear oil into it.
  16. Jul 23, 2018 at 11:05 AM
    jjbbing
    jjbbing [OP] Member
    Jack
    Vermont
    Just to clarify, it feels like starting from a stop in 4th, may be 2nd or 3rd, also could be described as trying to drive with the E-Brake on (not moving, pressing gas, reving up, no/minimal power to the wheels). My driveway has a good upward hill out of the garage and I wouldn't be able to make it up without waiting for it to warm up or by shifting to L.
    From the sounds of it, people are thinking its a solenoid or clogged up value body. Without codes to tell which solenoids... any suggestions or wait it out til it gets worse? Am I going to do any damage by continuing to drive?
  17. Jul 23, 2018 at 11:59 AM
    gearcruncher
    if it is slipping and the engine is revving , you are doing damage .
    Have you checked the fluid level ? a fluid pressure guage will be needed to continue diagnosing
    Try backing in to the driveway when you get home in order to avoid causing the trans to slip every morning during warm up
  18. Jul 23, 2018 at 7:28 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    If I were you I'd run to a transmission shop and see what they say. You risk your steels and disks in the clutch if it slips too much. They will overheat and glaze...then fail. I'd minimize the damage and the $ spent by said damage.
  19. Aug 15, 2018 at 2:32 PM
    jjbbing
    jjbbing [OP] Member
    Jack
    Vermont
    Thank you all for the inputs. I ended bringing the truck into a transmission shop (AAMCO) for diagnosis. They went through the truck, checked for codes etc and were not able to find anything. They wanted it for another day to drop the pan and also mentioned some TSB about programming the transmission. I haven't gone forward with any of that, given the uncertainty of any true fix I didn't want to rack up a bill for nothing.
    Kind of back to square one... been thinking about selling and upgrading to a 3rd gen soon (don't want to deal with reliability issues of an aging and starting to rust vehicle and with work I need a reliable vehicle). This issue however makes me not want to sell the vehicle with an unknown issue... but I'll def loose some $$ if I do a trade in.
    Thanks for the help!
  20. Aug 15, 2018 at 3:35 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It's more like it holds the gear a little longer in the hopes it will warm up faster.
