1st gen 2nd gear grind?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kingbrian, Sep 11, 2011.
  1. Sep 11, 2011 at 2:03 AM
    kingbrian
    kingbrian [OP] Resident Big mouthed Fat ass.
    brian
    I.E. CA.
    98 2.4 5 speed xtracab
    Fagtech spindles, Doug Thorley header, Spintech muffler, JVC headunit.
    so i have searched and searched maybe im not usin the right words, but i got a 98 extracab sr5 5 lug with the 2rz and 5 speed. i do drive fast on the freeways and stuff and have been known to burn out here and there, but its also got 204k miles.. but about 10k ago i had no problems and recently second gear started to gring it has gotten worse to a point and then no longer gets worse.. if i shift at slowly or below 1900rpm its fine but the higher the revs the worse it grinds, but its not realy bad grinds just hard to get into gear kinda grinds.. when its cold it has no problems... ive changed the oil and put in royal purple synthetic with hopes but idnt hange much but maybe a little smotther operation all around.. any ideas??? is this normal?? is my trans gunna die? im ok with the grind if it will last otherwise... HELP!
  2. Sep 11, 2011 at 2:31 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I have a minor version of that problem when going into third (either up or down) as well. It came with the truck but its not getting any worse. I reckon it's the synchros or whatever. As long as it doesn't get worse and you don't mind it then you may as well let sleeping dogs lie.
  3. Sep 11, 2011 at 3:04 AM
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Kyb Shocks... for now
    the problem is inherent in all w59 transmissions. Nothing to be worried about, try to shift at 5k vs 5500, I noticed a reduction
  4. Sep 11, 2011 at 11:47 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    X2. mine does the same thing every now and then
  5. Sep 11, 2011 at 11:48 AM
    TACOMABOSS
    96 SR5 4x4
    maybe your not disengauging the clutch enough?
  6. Sep 11, 2011 at 11:58 AM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    5K shifts :confused:
    that seems a little high, I dont know what I shift at when accelerating onto the freeway, but i doubt its above 4k.
    I also can feel it catch an edge when shifting into 2nd on my 2003, came with the truck, dont mind it too much.
  7. Sep 11, 2011 at 12:03 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You said it does not do it when cold. Oil is thicker when it's cold. Maybe try a heavier oil in the transmission? I would think synthetic would make it worse, less friction for the worn syncro to grab.
  8. Sep 11, 2011 at 12:14 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    You shift at 5k!!!?!?! Holy shit you must really feel the engine when your foot touches the clutch! Geez, its not a Honda civic.
    I always and will always shift at 3000 rpm, thats what every other Taco owner i know does.
    I get 2nd gear grinding when the truck is cold. But its always fine after the temp goes up.
  9. Sep 11, 2011 at 1:22 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Here, lets actually read part of the OP statement:
    Note higher revs? this does not mean 5k shifts, this means 5k revs vs 5.5k revs when you're going up high in revs.
    Again, OP said he does burnouts and shit, every w59 grinds when shifting at high revs like he suggested.
    normal driving 1500-2500 is where i shift. you and every other taco owner you know are shifting too high to get decent mpg.
    Perhaps you could benefit from reading the OP statement as well.
  10. Sep 11, 2011 at 1:41 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    so where do you shift at?? 1500-2500 sounds right to me. But you said you noticed a reduction at 5k-5500
    I understand the revs, but thats pretty high still.
    Vtec?
  11. Sep 11, 2011 at 1:50 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    You're not getting it lol there is a reduction at 5k, vs shifting at redline. this would be for a launch situation, such as at a drag strip or a burnout like OP mentioned
  12. Sep 11, 2011 at 2:03 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    yeah guess i dont understand. Different strokes for different folks. I personally wouldnt ever rev my truck to 5k to drop the clutch and show off a sick one wheel burnout with open diff.
    My apologies
    :wave:
  13. Sep 11, 2011 at 2:51 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
  14. Sep 11, 2011 at 2:56 PM
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    I shift at 2700 so i dont need the clutch.
  15. Sep 11, 2011 at 2:57 PM
    TheMrGExperience
    Garrett
    Slidell, LA
  16. Sep 11, 2011 at 3:06 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
  17. Sep 11, 2011 at 3:25 PM
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    you dont even hear my truck take off from the honda burnout ;p
  18. Sep 11, 2011 at 3:48 PM
    DingDong
    DingDong Well-Known Member
    California
    1st gen
    haha ohh how some people dont know when to quit.
    +1 to rucas
    dmonkey still needs to grow up
    To the OP:
    it could be a number of things, maby just the number of miles on your trans, and how its been treated throughout its 13 years of life. Could be the synchros. Like others have said, if it gets worse i would take it in. (also if it gets worse after doing a burnout, you found your problem.)
  19. Sep 11, 2011 at 8:06 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    It's your shift fork. It's getting ready to snap :D
    Point proven.
    Every W59 grinds unless it was babied from the start of it's life and ran a GOOD gear oil.
    Put Redline MT-90 in it..it'll smoothen the shifts. If you keep slamming gears, it'll break. A new transmission is like $200 though.
    I got 68k miles out of slammin the hell out of that transmission, grinding 2nd, etc. All kinds of shit. I split the case and it looked brand new inside but the shift fork fell out right when I split it lol.
    P.S. 7.5 Rear ends lock up alot
    Point proven again.
  20. Sep 11, 2011 at 10:45 PM
    kingbrian
    brian
    I.E. CA.
    yeah so just to be clear when the trans is cold every gear is a little stiffer than when warm but no gear grinds not even 2nd.. But once the trans get a little warm 2nd will grind with any RPM's over about 1900-2000.. if i shift before that even quicker shifts i get no grinding.. BUT if i shift slow even say a 5k rpm shift while warm if i take my sweet time which makes it pointless to even shift that high, basically let the revs fall back to damn near idle it wont grind at all.. in my head it seems like syncros cuz of that but the hot and old difference throws me off. i bought the truck off a dead old man (his wife), its not abused and in good shape and well maintaned for the miles its got but the bed shows some use.. so i dont really know. i have only put about 20k on the truck and when i got it it didnt grind, but it was a little stiff. i dont care about the grinding but i wanna be able to trust the truck to drive it a distance.. maybe ill look or a used tranny.. hey Undefined, did you rebuild your tranny?? how bad was he job?
