1st gen 3.4 alternator
Discussion in 'Technical Chat' started by HerNameIsLucy, Dec 15, 2008.
  1. Dec 15, 2008 at 4:28 PM
    HerNameIsLucy
    HerNameIsLucy [OP] I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Does anyone know the output amperage rating for the 1st gen alternator on a 3.4 truck? no towing package.
  2. Dec 15, 2008 at 6:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    From what I remember its between 60 and 70 amps.
  3. Dec 15, 2008 at 6:41 PM
    HerNameIsLucy
    RIP Lucy.
    Thanks Chris. Kinda thought it was wimpy like that 'cause when I have the heads on and turn the off-roads on the dash lights dim and recover ever so slightly and quickly.
  4. Dec 15, 2008 at 6:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can get a higher out put alternator, if you find you might need one. OR, your can be re wound for a higher output. With your lights, 100 amps would be pretty good. Thats one of the reasons I havent put lights on mine, is because of the low alt output. :(
  5. Dec 15, 2008 at 6:58 PM
    HerNameIsLucy
    RIP Lucy.
    I have a 1 Farad "Punch" cap in the garage from an audio setup a few vehicles ago. Was kicking around somehow using it to cover the drop when I switch the off-roads on. If I put it on the always hot side of the lamp circuit it would just be basically another battery, but if I put it on the switched side it would be worse since it would have to charge up before it helped, by then it wouldn't be needed.
  6. Dec 15, 2008 at 7:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i had been wondering about my alternator too when i bought my truck, since it doesnt have the tow package. where can i get a 100 or 120 amp alternator that will work, besides toyota?? anyone know??
  7. Dec 15, 2008 at 7:05 PM
    HerNameIsLucy
    RIP Lucy.
    rockauto sells 80 amp units. wonder if a unit out of a different toyota would mount up without too much modding? junkyards are full of wrecked camrys etc.
  8. Dec 15, 2008 at 7:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what is the output of an alternator out of a tacoma with the 3.4 v6 and the tow package??
  9. Dec 15, 2008 at 7:07 PM
    HerNameIsLucy
    RIP Lucy.
    excellent question. none of the catalogs i normally check even ask if it's for a tow pack vehicle or not.
  10. Dec 15, 2008 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Around 110 amps. They will bolt right in with no mods.
  11. Dec 15, 2008 at 7:25 PM
    HerNameIsLucy
    RIP Lucy.
  12. Dec 15, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  13. Dec 15, 2008 at 7:29 PM
    HerNameIsLucy
    RIP Lucy.
    wow! i'd be scared it would take something else out in the wiring!
