1st gen 3.4 TRD super charger
Discussion in '1st Gen. Tacomas (1995-2004)' started by FJZooga, Mar 16, 2017.
  1. Mar 16, 2017 at 5:31 AM
    FJZooga
    FJZooga [OP] Well-Known Member
    Rob
    Sonoma County Ca.
    FJ40
    what is a good price for a used 3.4 TRD super charger and what are some of the things I should look for?
    I found a TRD super charger with headers for $3,000 but the price seems high
    any advise is appreciated
    Thanks,
    Rob
  2. Mar 16, 2017 at 5:53 AM
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    Why not get a new unit: http://www.magnacharger.com/
    TOYOTA 5VZ-FE 3.4L V6 SUPERCHARGER SYSTEM
    Our Price: $2,995.00
    Product Code: 01-62-34-003-BL
    Magnuson Toyota 3.4L MP62 Supercharger SystemMagnuson is proud to announce the Toyota 3.4L V6 Supercharger System is now available for the Toyota Tacoma, 4Runner, T100 and Tundra. The OEM look of our integral supercharger system on this platform allows for a one piece design, a larger plenum and tapered runners just to name a few advancements. At around 6 psi, the 3.4L V6 Supercharger System makes an amazing 25% hp and 25% lb-ft increase of serious truck torque at the crank, all with CARB certification (D-488-42).
    At the heart of the Magnuson Supercharger System is Eaton’s fifth generation supercharger unit, the MP62. The supercharger system is a positive displacement, roots style pump, utilizing Eaton’s lightweight, three-lobe 60 degree twisted rotors. Cast and assembled as a single, OEM-style-manifold and rotating group housing, the unit is quiet, compact, attractive, easy to install, and requires little to no extra maintenance to the unit itself.
    The positive displacement supercharger offers power instantly as the throttle is pressed. Boost pressure builds with no perceived lag commonly associated with other types of forced induction, and provides a large increase in torque across the entire power band. Throttle control is linear and predictable and makes for an excellent driving experience both in daily driving and wide-open acceleration.
    Since the supercharger does not compress air as it moves through the rotors, it’s extremely efficient during light throttle and cruising situations. Unlike screw-type positive displacement superchargers that are always compressing, the MP62 unit can internally bypass air, resulting in negligible parasitic loss during cruising and therefore far greater fuel economy.
    The single cast unit and appropriately sized rotating group eliminates potential leak points and allows for a slim, compact design without sacrificing key airflow design characteristics. The unit features a high velocity flow path through the supercharger rotors and an unrestricted discharge port into the appropriately sized plenum. The large plenum equalizes flow across all ports as air feeds evenly into the runners. Finally, the ports are separated into individual runners, offering greater operation by eliminating cross-fire.
    Features
    • 25% hp & 25% lbs-ft increase at the crank in standard kit form on an unmodified truck
    • Includes Magnuson’s 3yr/36,000ml warranty
    • CARB certification (D-488-42)
    • Installs can be completed within one day
    • Also available for other 5VZ-FE 3.4L V6 platforms, other applications may require custom calibration.
    Warranty
    • Supercharger - 3 Year / 36,000 Mile Limited Warranty on supercharger hardware
    eon_blue likes this.
  3. Mar 16, 2017 at 1:27 PM
    eon_blue
    Azusa, CA
    For 3 grand I'd get a new one and save up for headers later on. The Magnuson's are CARB certified now it looks like so if you're in CA there's no reason to look for a used one unless you want to save some cash, but remember the superchargers need rebuilding at around 100k miles and that can easily cost you another $1k if you can't do it yourself.
  4. Mar 16, 2017 at 1:31 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Price seems high, I wouldn't buy new but it seems I've seen used complete kits w/o headers but with 7th injector for around 2k, maybe it was a lil more. I haven't really looked for them but what I've noticed.
  5. Mar 24, 2017 at 7:14 PM
    FJZooga
    Rob
    Sonoma County Ca.
    FJ40
    thanks
    I ended up buying just the supercharger for $2,000 it seems to be in good shape but I won't know until I take it apart. fingers crossed.
  6. Mar 24, 2017 at 9:01 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    TRD headers still might be available brand new at Bev Smith Toyota in Fl. A few of us grabbed them on EBay, they still might be available. I think I paid somewhere around $670...
  7. Mar 24, 2017 at 9:02 PM
    QMEDJoe
    Joe
  8. Mar 26, 2017 at 8:20 AM
    FJZooga
    Rob
    Sonoma County Ca.
    FJ40
    Thanks for all the info, glad that I didn't buy them.
  9. Mar 26, 2017 at 8:37 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    QMEDJoe[QUOTED] likes this.
  10. Mar 26, 2017 at 9:06 PM
    QMEDJoe
    Joe
    I'm very pleased with them. I got lucky and found a TRD Y-pipe that corresponds to the 99-04 Tacoma's. Two cats vs only one. This one is designed for the one cat only but it's not a big deal. Your local exhaust shop could make your current exhaust bolt up to it with just a little fabrication. Congrats on the purchase! :thumbsup:
  11. Mar 27, 2017 at 12:04 AM
    misteroldschool
    misteroldschool Well-Known Member
    98 4x4 2.7l
    prices are pretty high on superchargers unfortunately, i couldent find a used one and bought one new from these guys www.lceperformance.com
  12. Apr 26, 2017 at 1:37 AM
    1HItaco
    1HItaco Well-Known Member
    are the headers worth it without the supercharger?
    is it a "must" if you have the supercharger?
    and where would one find TRD Y-pipe that corresponds to the 99-04 Tacoma's?
  13. Apr 26, 2017 at 10:09 AM
    QMEDJoe
    Joe
    That's a tough question... I love my truck and make decent money. I did it because I know I'll s/c my truck some day but even if that doesn't happen I'm still happy with them. My truck sounded good with the Magnaflow Catback exhaust but really sounded awesome when I threw in those headers!
    If your going to boost then I would say yes, get the headers. It really allows your engine to expel that exhaust that much faster. Plus they're discontinued. They're expensive but prior to them being available people were on here selling they're old ones for the same price they bought them for, once EBay no longer has them you won't lose money if you ever need to sell them.
    The y-pipe I have @TashcomerTexas to thank, he found me the part # and I went searching. It just so happen to be that I found one. From what people have said since these headers have been available that well is all dried up. I'd still buy em again, even if I never boost (which I will) but if your not going to s/c your truck and could care less about sound, I'd throw the money toward your next mod... Lift, lockers or tires.
    Mdslawn and TashcomerTexas like this.
  14. Apr 26, 2017 at 10:23 AM
    QMEDJoe
    Joe
    Not having the y-pipe shouldn't discourage anyone. It's an easy fix for an exhaust shop. Some light fab work and a URD o2 sensor simulator will have it running same same.
  15. Apr 26, 2017 at 7:01 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
