1st Gen 3.4 Vacuum Hose Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jnorris, Mar 19, 2019.
  1. Mar 29, 2025 at 2:35 PM
    #241
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Mine are still in great shape. After installing I notice a rapid "swooshing" sound under the hood I can't pinpoint, like a sucking wind sound. Has never affected anything, but sounds kinda funny at idle.
    Black97v6MT likes this.
  2. Apr 24, 2025 at 10:12 AM
    #242
    finslayer83
    finslayer83 Well-Known Member
    TN
    TRDP 4runner / 01 Taco
    A lot
    ordered.
    I think cracked hoses are causing my EVAP CEL
  3. Apr 24, 2025 at 6:01 PM
    #243
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Could be, what's the CEL code?
  4. Apr 24, 2025 at 6:29 PM
    #244
    unstpible
    Derek
    Cedar City, Utah
    Mine are holding up well even with the added heat and pressure from the Turbo if you're still wondering. I did swap out the Silicone lines going into the PCV valve and the rear crank case vent on the other side. I started seeing liquid seep through the PCV line so I switched to 3/8ths fuel line to prevent that from happening again. I might have some pictures of the seepage in my build thread somewhere with a better explanation of why Silicone lines aren't great for those specific spots but it boils down to fuel vapors and silicon not playing nice with each other
  5. Apr 24, 2025 at 11:05 PM
    #245
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I had a similar problem with mine. I was getting a high idle I think. Took it to a mechanic they did a smoke test and the hose swap fixed the issue
    unstpible[QUOTED] likes this.
  6. Apr 25, 2025 at 8:02 AM
    #246
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Yup that’s what I had read was silicone hoses do not mate well for petrol based applications. Looks like I’ll get around to buying one of these kits soon.
  7. Jun 24, 2025 at 2:05 PM
    #247
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    Stumbled upon this thread which reminded me that I ordered this kit back in Feb 2019. Just found it sitting in a USPS box on a shelf in the garage. After reading through the thread, I saw that there was a problem with the silicone lines attached to the brake system collapsing causing braking issues. Has this for sure been fixed?
    Area51Runner likes this.
  8. Jun 25, 2025 at 8:01 PM
    #248
    Kiloyard
    Phoenix, AZ
    I'm still running these silicone hoses on the brake booster and I haven't noticed a problem - but maybe I'm just unaware. I do have a "swooshing" sound I can hear at idle since making the change.
  9. Jun 26, 2025 at 12:58 PM
    #249
    jeg0005
    Jon
    BHM, AL
    When did you buy them?
  10. Jun 28, 2025 at 1:56 PM
    #250
    Kiloyard
    Phoenix, AZ
    5 or 6 years ago, according to my post history. I think the one hose I kept stock was the PCV hose.
  11. Aug 15, 2025 at 7:25 AM
    #251
    Zachoma
    Zachoma New Member
    Zach
    2003 Tacoma TRD 4x4
    32” tires
    I had this same sound from switching to silicone hoses. I swapped back my hose from the vsv to the top of the intake plenum and the sound went away. The silicone hose must not insulate noise as well as the OEM hoses. Hope this helps.
    Kiloyard[QUOTED] likes this.
  12. Aug 16, 2025 at 6:26 PM
    #252
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I just removed the silicone hoses I installed recently, I think the silicone hoses were collapsing when the engine compartment warmed up, I had weird symptoms. I prolly bought some cheap silicone stuff. Throwing that shit in the garbage
    tacoma_ca and Zachoma like this.
  13. Aug 16, 2025 at 6:49 PM
    #253
    Zachoma
    Zachoma New Member
    Zach
    2003 Tacoma TRD 4x4
    32” tires
    Good call, I’m doing the same. Fuel line is a safe bet.
    Moonrman likes this.
  14. Aug 19, 2025 at 5:43 PM
    #254
    JR_Roams
    JR_Roams Well-Known Member
    2002 Tacoma TRD-OR EXC 5MT
    From these recent replies im not so sure I want to do this mod. Did you guys use hose from siliconeintakes.com? What's the consensus? collapsing lines? good idea? bad idea? Skip the pcv and brake booster?
  15. Aug 19, 2025 at 5:48 PM
    #255
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Definitely not a good idea for me, I thought I bought good silicone hoses, the wall thickness looked good, but I’m sure they were collapsing when hot. I was experiencing some weird symptoms, sluggish acceleration, wonky idle, i re-installed the old hoses and all is good now.
    JR_Roams likes this.
  16. Aug 19, 2025 at 7:08 PM
    #256
    JR_Roams
    This mod was so tempting until these recent replies, so im glad you guys chimed in. Maybe there's a vendor that sells a more rigid and robust grade of silicone that we can try, but for now...mmm no.
