1st gen 3.4l supercharger.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2wdPrerunner, Feb 25, 2025.
  1. Feb 25, 2025 at 8:39 PM
    2wdPrerunner
    2wdPrerunner [OP] Member
    2003 tacoma 2wd prerunner
    I need help. She was running ok. For a year or 2. All of a sudden, she took a shit. Now she cranks and cranks and wants to fire but won't stay unless I press the gas. Does any one have a fuel map for the urd AIC/timing calibration computer I can try or have any suggestions I can try.
  2. Feb 25, 2025 at 9:25 PM
    02hilux
    Planet: EARTH
    The URD ftc is essentially relabel split second ftc. That unit will only function under boost and will have nothing to do with cold start. You can actually unplug it and cause no harm to any components in case you’re wondering.
  3. Feb 28, 2025 at 11:53 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    It's your IAC is stuck close. Adjustments are only needed to the Urd to retard timing in case of detonation. You will lose power by making your truck retarded.
  4. Mar 1, 2025 at 4:05 PM
    2wdPrerunner
    There is not a removable iac valve on it. How do I fix that from being stuck closed? And I changed the spark plugs and oil, and she fired up and idled good. Then I shut it down came back out to start it up again and would not fire. I changed the oil because there was a lot of gas in it. Also maybe or not, but I relocated the battery into the bed.
  5. Mar 2, 2025 at 11:40 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Sounds like it could be a leaking fuel injector.
    Also, the IAC valve is mounted on the underside of the throttle body, not on the SC. Remove the TB to access the IAC.
  6. Mar 2, 2025 at 12:27 PM
    2wdPrerunner
    Thanks. I'm cleaning the injectors and I'll clean the IAC while I have it out
  7. Mar 2, 2025 at 1:11 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Your 03 does not have an IAC valve if it has electronic throttle control. A few very early 03s still had an IAC.
    If the t body has a small blank rectangular plate on the top it's the ETC version without an IAC.
  8. Mar 2, 2025 at 3:23 PM
    2wdPrerunner
    It is the one without an IAC. So now any other suggestions will be helpful. It is getting frustrating.
  9. Mar 3, 2025 at 2:39 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Anyway to do a quick bypass of the piggyback? Would be useful to be able to totally remove that from the equation. Its one reason I'd like to un-do my larger injectors and go with a RRFPR instead so that I can easily bypass my piggyback sometimes.
