1st gen, 350k miles, #3 cylinder misfires when cold...tried it all?
Discussion in 'Technical Chat' started by rchrds, Apr 14, 2023.
  1. Apr 14, 2023 at 1:50 PM
    rchrds
    rchrds [OP] Well-Known Member
    TN, USA
    2024 Trailhunter
    So, I've replaced the spark plug (all of them), coil pack (all of them) injector (all of them) and wires. The OBDII reader shows #3 cylinder misfire. When starting from cold you can feel the rough running for about 15 seconds, then it clears up and runs smoothly. If I clear the fault after it warms up It doesn't recur until the next day start after sitting all night. The plug had more build up than the others (I swap them at 25k, usually they are light brown, #3 appeared damp, and black. Every indication is that oil is leaking past the rings and soaking the plug, causing the rough cold start, then burning off when it warms. There's only a slight increase with oil burn (from not noticeable for the first 330k miles, to about 1/3 quart at 5000 miles oil change which also correlates. The only thing I haven't done is a compression check on the cylinders. Am I missing anything else? In the long run, I'm not really feeling up to a ring replacement in this engine.
  2. Apr 14, 2023 at 1:53 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...you checked for a blown head gasket?
    Dm93 likes this.
  3. Apr 14, 2023 at 2:03 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Which engine is it?
    rchrds[OP] and Dm93 like this.
  4. Apr 17, 2023 at 5:22 PM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    Do a compression check. You might have a burnt valve possibly.
    rchrds[OP] likes this.
  5. Apr 21, 2023 at 1:19 PM
    allwaysbroken5
    allwaysbroken5 Well-Known Member
    jerry
    2010 Tacoma 2.7 manual
    none
    compression check so many miles may need rebuild
