1st gen 35s will this off set work? 17x9 -12
Discussion in 'Wheels & Tires' started by Old green toyota, Feb 19, 2025.
  1. Feb 19, 2025 at 10:25 PM
    Old green toyota
    Old green toyota [OP] Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    I just did 5.29 and e locker. Looking to move up to 35s. But need help choosing offset. I'm going with BFG ko3 tires. 35x12.5
    I know I have to chop the cab, very comfortable with that part. Probably need to move the washer tank too.
    But i don't want to get stuck with wheels that won't work.
    Is -12 enough? I think .5 is about as big as a spacer as I'd feel comfortable running. Not a big fan of wheel spacers, rather just get the offset right.
  2. Feb 21, 2025 at 11:24 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Enough for what? The -12 will clear the uca.
  3. Feb 21, 2025 at 12:15 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    Enough to clear the frame, and minimize cutting of the firewall. I'm ok with cutting, but rather not lose a ton of footspace.
  4. Feb 21, 2025 at 5:12 PM
    gotoman1969
    You will have to cut no matter what. It just comes down to how much and where. The more offset more of the fenders less offset more interior area. When fitting 35s all you can do is pick the wheel you want, mount them and start cutting till the clear thru the full cycle of the suspension.
