1st Gen 4wd Solid Transmission Mounts For Sale
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Bonzen, Jan 7, 2016.
  1. Jan 7, 2016 at 6:29 PM
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Just completed the prototype for a member on here. This is a perfect compliment to my solid motor mounts and is based around the same hard polyurethane bushings. Bolts to the stock factory cross member (new bolts will be supplied) and to the aluminum transmission case. No modification/fabrication required. Have a truly solid mounted drivetrain for serious off-roading and more positive throttle response. The 3.4L manual transmission and T-case is extremely heavy and is a lot of weight to be supported by solid motor mounts alone! I have personally cracked the aluminum housing from over flexing of the stock tranny mount and in conjunction with broken/over flexing motor mounts...this will cure all those possible problems common with heavy off-roading/hitting whoops/jumping.
    Price is $425, I take PayPal ryan_tfg@hotmail.com
    Message my inbox if interested!
  2. Jan 7, 2016 at 11:01 PM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    :eek:
    Straight up beef.
    12TRDTacoma likes this.
  3. Jan 19, 2016 at 3:00 PM
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Installed on customer truck - no more sloppy stick!
  4. Jan 19, 2016 at 3:33 PM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    do you offer a package discount if you get this along with the engine mounts you make? nice work btw
  5. Jan 19, 2016 at 6:08 PM
    Bonzen
    Lake Havasu City
    The Silver Bullet
    Everything.
    Ill do the tranny mount and engine mounts for $750. (plus shipping)
