1st Gen Aftermarket Clutch Recommends?
Discussion in '4 Cylinder' started by RockTock, Oct 24, 2013.
  1. Oct 24, 2013 at 1:59 AM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    Ive got the 4.2 engine, not sure if OEM are as 'bad' as 2nd gen, or are there good alternatives?
    Also, how do you find a good mechanic to put it in? What are the 'rules' for parts they don't order, or can they order the same part? Your experiences. Thanks
  2. Oct 24, 2013 at 2:04 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    you've got the 2.4 not the 4.2 ;)
    Get a Marlin Crawler 1200lbs
    I've got it and I'm extremely happy with it
    I've never heard someone who got it (lots of folks on here have) and said anything different
    http://www.marlincrawler.com/clutch/heavy-duty/heavy-duty-clutch-kit-1200-lb
    I ordered this kit, which comes with everything you need; unless you need a new flywheel
    Which, I did; so, I ordered one of them too
    I brought it to a Mechanic Shop and they installed it
  3. Oct 24, 2013 at 12:02 PM
    RockTock
    Colorado
    That would explain why its only crawls up those steep highway hills!
