1st Gen Aftermarket Coils? Field Tested
Discussion in 'Suspension' started by Jet3Bamafan, Jan 30, 2018.
  1. Jan 30, 2018 at 2:57 AM
    Jet3Bamafan
    Jet3Bamafan [OP] Active Member
    Trey
    Livingston, Montana
    1998 Toyota Tacoma sr5 4wd Ext Cab
    Leer camper shell, Cabelas Cargo Rack,LED interior Map Lights
    I need to buy new coil springs soon to pair with new bilstein 5100s. From your experience which would you recommend. Will be running an ARB bumper and possibly a 9k-12k winch shortly after installing new coilover setup. I`m trying to decide between OME 882, OME 883, or Toytec 112-620. Looking for 2.5-3" of lift. Suspension will be going on a 98 Tacoma ext cab 3.4l 4x4. Also installing the OME 250kgs leaf springs in the rear if that makes any difference. Thank you for the advice.
  2. Feb 2, 2018 at 9:29 PM
    Jet3Bamafan
    Trey
    Livingston, Montana
    Nobody have any input with either springs with this same setup? Any input on the coil springs themselves?
  3. Feb 3, 2018 at 8:37 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Personally I'd go for the 883's. The 882's have a 500lb/in spring rate, while the 883's have a 590lb/in spring rate which will be better with your bumper and winch. I had the 880's on my truck and I liked them a lot. For the price, they were hard to beat.
    I don't have any experience with the Toytec/Eibach coils, although most who have them say they ride pretty stiff (620lb/in spring rate), but since you have extra weight you'd probably be fine.
    Jet3Bamafan[OP] likes this.
  4. Feb 4, 2018 at 9:59 PM
    Jet3Bamafan
    Trey
    Livingston, Montana
    Thanks for the input. I think I`ll go with the 883`s
    03 NIGHT TACO[QUOTED] likes this.
  5. Feb 4, 2018 at 10:11 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I'm pretty sure this as been discussed ad nauseam for many years. Do a search.
