1st Gen ARB Bull Bar Front Bumper Pictures
Discussion in '1st Gen. Tacomas (1995-2004)' started by Low Range Off-Road, Dec 19, 2016.
  1. Apr 13, 2020 at 11:17 AM
    #81
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Love the 240s. HID?
  2. Apr 13, 2020 at 11:19 AM
    #82
    Arctic Taco
    Denali Park, Alaska
    Where in Fremont county? I grew up in Dubois
  3. Apr 13, 2020 at 4:10 PM
    #83
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    Arctic Taco[QUOTED] likes this.
  4. Apr 13, 2020 at 6:55 PM
    #84
    JakesTacoTRD
    JakesTacoTRD "Winona the Tacoma"
    Jacob
    Gainesville, FL
    2001 White Tacoma SR5 TRD 4x4 5 speed
    Smooth!
  5. Apr 13, 2020 at 7:14 PM
    #85
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    Thanks. Looks great.
    JakesTacoTRD[QUOTED] likes this.
  6. Apr 13, 2020 at 9:31 PM
    #86
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Thanks man! Here are two photos now that I switched to 4runner rims!C9DE17CA-DC7C-405A-BC9F-7B5191CAC81A.jpg460A8060-17D4-4055-88E9-650131064076.jpg
  7. Apr 13, 2020 at 9:39 PM
    #87
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Old thread, but here’s my not so lightly used ARB0C36106B-278A-4F18-9189-130E5AF5AB35.jpg
  8. Apr 14, 2020 at 8:19 AM
    #88
    Arctic Taco
    Denali Park, Alaska
    Right on, it’s been quite awhile since I got over that way, but it’s on the list in a couple years to do some roaming around there again. We used to go over around Jeffery City for antelope hunting back when I was in school, so some of you photos looked somewhat familiar terrain wise. Since I had a 52 CJ2A, I didn’t roam too far afield, mostly up in the Absoraka and upper Wind Rivers, it would take forever to run the old Willy’s down that way. Enjoy it, I miss it.
  9. Apr 15, 2020 at 7:32 PM
    #89
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Bought them as 100watt halogens. Converted them to 100watt HIDs and didnt like them. Converted them back to halogen. Took them off and ran a Rigid 20" light bar instead. Way more usable light. They are not good offroading. Maybe long straight flat stretches in Australia where they were designed and made. But not the PNW.
    ontarioyota likes this.
  10. Apr 16, 2020 at 3:20 AM
    #90
    rybern
    N Alabama
    Hey guys, Can someone measure the diameter of the grill/headlight tubing? Does anyone know what the specs are on it? Wall thickness, DOM, etc?
  11. Apr 16, 2020 at 5:48 AM
    #91
    Arctic Taco
    Denali Park, Alaska
    Yeah I run some 240’s on my diesel, and some 170s for ditch lights. They work pretty good up north, but they hydro-axe the the ditches so that helps. On the fence about a light bar, I might build one up from the Ridgid cubes and mount it on the top of the bull bar. I liked the IPFs that came with the bumper, but one got cracked while the cover was on on the AlCan last trip up, so I am trying these Anzos and I have a couple Super bright LEDs that I mounted where the push pads went, they might do in the short term. Hard to find something that fills all needs.
    Just about done trimming the buckets for the Hella E code 97 sealed beam swap, just some tweaking to get them to fit right in the 97 grill, then finish painting the grill and see what the light pattern looks like and go from there.E69FC75F-F032-480C-B33A-B3DDED5CCABE.jpg
    Phessor and arctic04trd[QUOTED] like this.
  12. Apr 29, 2020 at 10:19 PM
    #92
    NuubTaco
    NuubTaco Member
    Lyons, CO
    2004 Tacoma X-tracab 4x4 n'stuff
    Billie 5100s w/ OME 883s and OME DAkars w/ XLs, ARB Roo Bar, Warn M8000 winchy, Bud Built full slider kit, Toyo
  13. May 6, 2020 at 2:18 PM
    #93
    Carl 9.3x62
    Carl 9.3x62 Member
    2004 Tacoma Double Cab
    Is your truck lifted at all?
  14. May 6, 2020 at 3:07 PM
    #94
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Yes sir, 2.5 in the front (5100s) and 1.5 AAL in the rear
  15. May 8, 2020 at 2:36 PM
    #95
    Joey_Bada_Bing
    Joey_Bada_Bing Well-Known Member
    North Carolina
    1st Gen DC 4WD
    A bunch of the same stuff everybody else has already done.
    I may have missed this earlier in the thread but is the install reversible if I decide to go back to the factory bumper ?
  16. May 8, 2020 at 2:37 PM
    #96
    Kwikvette
    Fresno County
    4 run, 2 don't
    Absolutely.
    It's simply bolt on.
  17. May 8, 2020 at 2:37 PM
    #97
    Joey_Bada_Bing
    North Carolina
    1st Gen DC 4WD
    right on, thanks
  18. May 8, 2020 at 3:58 PM
    #98
    Lil'gray
    Lil'gray New Member
    Christopher
    out west (DENVER TOWN)
    2002 Tacoma gen1 (real tacoma) regular cab
    Kickin the tires
    Hello, how did you mount these Light force lights? do they fit on the ARB mounting holes? Thanks
  19. May 8, 2020 at 7:12 PM
    #99
    xtwillie
    xtwillie Well-Known Member
    Kevin
    03 Tacoma
    This is super Sick
  20. May 8, 2020 at 7:28 PM
    #100
    JakesTacoTRD
    Jacob
    Gainesville, FL
    Yes, direct bolt too for Tacoma. Seems that the 4runner is the only one you need to cut
