1st gen BAMF Skids!!
Discussion in 'Automotive Group Buys' started by Blackdawg, Jan 26, 2018.
  1. Apr 29, 2018 at 2:19 PM
    #221
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  2. Apr 30, 2018 at 12:09 PM
    #222
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
  3. May 1, 2018 at 3:12 PM
    #223
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Is it known if these will cover the LCA bolts and tabs?
  4. May 1, 2018 at 7:51 PM
    #224
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Highly doubt it
  5. May 1, 2018 at 7:56 PM
    #225
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    hmm. I thinking I'm in for 1, possibly 2 sets. I will check back later this week.
    FirstTimeFirstGen likes this.
  6. May 1, 2018 at 8:13 PM
    #226
    Misplaced Nebraskan
    Zach
    Austin
    :D
  7. May 1, 2018 at 8:31 PM
    #227
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think it's a possibility. Our trucks are narrower than say a 2rd gen in that area. BudBuilts cover the front cam adjuster bolts. These skids might also.
  8. May 2, 2018 at 5:00 AM
    #228
    Misplaced Nebraskan
    Zach
    Austin
    morning crowd bump... :fistbump:
  9. May 3, 2018 at 1:19 PM
    #229
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Tickling two thirds...
    Misplaced Nebraskan likes this.
  10. May 3, 2018 at 1:22 PM
    #230
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    i won't know until i get under the truck and start designing. They need to work with our LCA skids so time will tell.
  11. May 9, 2018 at 1:46 PM
    #231
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    So 1 or 2 sets?
    BuMp
  12. May 9, 2018 at 7:59 PM
    #232
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    None at the moment. Trying to figure out if I want to build the tacoma more, or keep it as a daily and build my fj40.
    The other set was going to be for my dad's 4runner, but he's not looking for any right now.
  13. May 9, 2018 at 8:13 PM
    #233
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    fj40 for trailer queen. Taco for long distance more comfortable rig.
    FirstTimeFirstGen and Prayn4surf like this.
  14. May 13, 2018 at 11:14 AM
    #234
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    Would the design fit on the 3rd gen 4runner?
  15. May 13, 2018 at 8:29 PM
    #235
    FirstTimeFirstGen
    David
    Pacifica
    On very little to no data and zero confidence in my answer, I'm going to say yes. So you're in for a full set. Right?
  16. May 13, 2018 at 8:46 PM
    #236
    Blackdawg
    Monte
    Wyoming/St. Louis
    couldnt say for sure. Should be i don't know.
  17. May 14, 2018 at 3:08 AM
    #237
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    If other skid companies have identical part numbers for the 1st gen tacoma/3rd gen 4runner, then there is a good chance.
    Good luck with the research
  18. May 14, 2018 at 4:06 PM
    #238
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    RCI’s skids for 1st gen tacos and 3rd gen 4Runner are sold as one in the same with the exception of the T-case skid. The 3rd gen runner has an additional crossmember behind the transfer case that the Tacoma’s don’t have. That’s the only difference I know of. It’s also why BudBuilt sells a crossmember for their skids, because there’s nowhere to mount the back half of a transfer case skid on a 1st gen Tacoma. Hope this helps.
  19. May 17, 2018 at 3:42 PM
    #239
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
  20. May 21, 2018 at 6:27 AM
    #240
    beez65
    beez65 Well-Known Member
    Oakland, CA
    2004 Double Cab 4x 3.4 AT
    Bilsteins, ToyTech, AAL, American Racing wheels, stock size tires. FOR NOW! :)
