1st Gen Bed measurements please!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MESO, Jul 17, 2018.
  1. Jul 17, 2018 at 10:06 AM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Hey guys,
    Can anyone measure the distance from inside bedrail to bedrail. I am looking at a 1st gen Bamf RTT bed rack for a good deal, trying to see if it will fit in my 3rd gen. Thanks!
  2. Jul 17, 2018 at 10:40 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It will not. The 2nd and 3rd gens are longer, wider, and taller than the 1st gens.
    I mean, you could probably get some plate to fill in the gaps, but IMO wouldn't look/function that great...
  3. Jul 17, 2018 at 10:41 AM
    MESO
    State of Jefferson
    Length isn't an issue(I have long bed). I'm more than prepared to section the middle and extend or shorten it fit between the bedrails. Not worried about height, as I want it pretty tall.
  4. Jul 17, 2018 at 10:44 AM
    jbrandt
    Justin
    I mean the 2nd and 3rd gen trucks themselves are longer, wider, and taller than the 1st gens. The bed width is different, though.
    You'd likely need to section the length and width.
  5. Jul 17, 2018 at 10:46 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If someone hasn't responded to this by the time I'm off work I'll measure mine for ya
    MESO[OP] likes this.
  6. Jul 19, 2018 at 5:09 PM
    Speedytech7
    Forgot about this, I'll go measure now...
  7. Jul 19, 2018 at 5:19 PM
    Speedytech7
    57 on the mark
    1bronco47 and MESO[QUOTED][OP] like this.
  8. Jul 19, 2018 at 5:24 PM
    MESO
    State of Jefferson
    Thank you!
    Speedytech7[QUOTED] likes this.
  9. Jul 19, 2018 at 5:36 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Out of curiosity how wide is a 3rd gen bed
  10. Jul 19, 2018 at 5:47 PM
    MESO
    State of Jefferson
    I just went out and measured my 3rd Gen. 57” from inside to inside
    Kpatt9 likes this.
  11. Jul 19, 2018 at 5:48 PM
    Speedytech7
    From what I remember putting my rack on a third gen it hits your tie down rail thingies but that's a pretty easy fix.
  12. Jul 19, 2018 at 6:41 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    DOUBLECAB your bed dimensions are 61.5x57.9
    xtra cab are 74.5x57.9
    so, 57.9"
    Chucktron likes this.
  13. Jul 25, 2018 at 12:08 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Interior length and width of all Tacoma long beds is the same. GFC found that out when they went to make a first gen specific model.
  14. Jul 25, 2018 at 1:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The tops of the bed rails are what is different. The bed rails on 2nd and 3rd gens are much wider than the 1st gen bed rails. This means that canopies designed for 2nd and 3rd gens don't line up with the outside edge of the 1st gen beds. As Zane documented, the I.D. between the rails is the same between 1st, 2nd and 3rd gen beds.
    Willbeck likes this.
