1st Gen Bilstein 5100 Part Numbers
Discussion in 'Suspension' started by scocar, Jul 30, 2010.
  1. Nov 8, 2010 at 11:00 PM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    hey Is it true that if you use taller springs (for example the 881s) with the front 5100s that it will limit the down travel of the shocks?
    I thought that the 5100s were designed to work with a 0 to 3 inch lift...
  2. Nov 9, 2010 at 9:04 AM
    scocar
    scocar [OP] Patron of the Farts
    No, that doesn't sound right. The longer shocks (5100s) work with the longer springs (881s are about 2 inches over stock) so that downtravel will not be limited.
  3. Nov 9, 2010 at 10:05 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Ok thanks.
  4. Dec 17, 2010 at 6:05 PM
    thebaugh23
    thebaugh23 Member
    Eston
    blueridge mountains
    99 TRD 4cyl ex-cab
    3" ToyTec lift. keyless entry/ alarm. XM radio. westing burshguard, super 44 flowmaster, tinted windows, A/T tires, New Bilstein HD shocks
    has anyone had to replace the rea shocks yet. how long did it take and can i do it in garage with simple tools. is there a vid on it or steps? does anyone have any good tips. im replacing my this weekend with replacement bilsteins
  5. Dec 17, 2010 at 6:26 PM
    scocar
    It's about as basic as a job can be (this assumes you don't live in a heavy snow/salt area, in which case you should have a sawzall, flamethrower, and hand grenades handy). Four bolts, a little grease. You'll want to grease the rubber bushings a little so they slide on easier. I suggest hanging it from the top first and just start that bolt so the shock hangs loosely without falling off as you use both hands to push (compress) the bottom up and onto the axle. You can jack up the rear of the truck a bit so you don't have to compress the shock as much to get it on.
    I think it is 17mm (or 19, can't remember) bolts, 53 ft lbs on all four. See attached diagram.
  6. Dec 19, 2010 at 2:42 PM
    95.5 taco
    95.5 taco Well-Known Member
    Kyle Osborne
    Cochran GA
    1995.5 Tacoma, 1998 4runner, 2003 Tacoma
    little help please. i need 4 new shocks(front and rear) and i live on a ruff ass dirt road so i thought i might as well get the best of the best (bilsteins)! so here is where i need help......which 1s do i need if i have a 3" lift??
  7. Dec 25, 2010 at 4:59 PM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    what would be a good front coil for the 5100s instead of stock.or should i just replace the stocks
  8. Mar 1, 2011 at 1:23 PM
    mfkokoska
    mfkokoska Active Member
    matt
    sydney ns canada
    I want to get these shocks but I'm wondering if they will fit my 2.5 inch suspesion lift.
  9. Mar 1, 2011 at 3:24 PM
    newskooler
    newskooler Well-Known Member
    Nick
    Mount Shasta, Ca
    1997 ext cab base, 2012 Base Access cab, 2018 trd OR
    Mall Crawler
    what exactly do you mean by inch lift? body lift?
  10. Apr 21, 2011 at 9:47 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The 5100 series will accomodate a 3" lift..
    From what info I've gotten the Eibach/ToyTek coils perform best with the 5100's , this is the route I'm going.
    Yes...
  11. Sep 15, 2011 at 10:24 AM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Interesting that there are 5100s for the rear, with different part numbers drivers side and passenger side, same on Down South Motorsport's site, but I was told the rears are not good for stock ride-height, that quote, "If leaving the rear suspension stock, the compression bump stop on chassis may need to be modified."
    Anyone using the 5100 rears on the OE ride-height without blowing the shock?
    Also maybe a good update for the first post/thread, anyone have the Toyota part numbers for the rubber stem cushions and washers for two front struts? Don't want to re-use my 180K ones.
  12. Nov 28, 2011 at 9:13 AM
    BlackSportD
    Los Angeles
    I finally installed the package I ordered from Down South, 5100 fronts set to OE ride height (IMO actually the lowest perch seems to be a tad bit higher than OE, leveling the truck), and 5125s in the rear as I'm staying at the OE ride height for now.
    I didn't get the new OE rubber mount parts (my old ones are cracking a bit...), but I did buy the shocks with the optional boots, just to give me a warm fuzzy that no debris finds itself wearing down the seals.
    Edit*
    5100- Great shocks- not overly harsh at all, but sure as heck fixed the sway and certain bouncy tendencies my truck had, having the passenger side OE shocks blown. You can tell they are off-road valved vs. road comfort valved such as the KYB Monomax. If one is looking for street driving replacement only, the KYBs sound to be valved for that, more so than the 5100s. Still- Bilstein delivers- I can see why Down South gets them by the crates, and still runs out time to time.
    The 5125s I got for the rear as I was not lifting the truck-- ensure you install them 'right side up', despite all the interwebz arm chair engineers saying it doesn't matter, for whatever reason on these shocks, it does. 5125s come in one flavor, 255/70. Its not bad, but IMO I would like the 170/60 better. I like firm and highly dampened feel in a sporty car or autocross build- the scene I'm coming from, but with my truck I have all this wheel travel potential I didn't have with my cars, and no need to improve lateral Gs, so I want to put the travel to use and make it a pot-hole eating cruiser- the 5125s are too firm. Maybe I'll change my mind when off roading and the 5125s are more controllable than the 5100 fronts.
  13. Dec 22, 2011 at 2:57 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    FYI
    I just ordered a set of 5100's for my 2004 4x4 from DSM. They came WITH bushings...
    I asked at DSM for the bushings, and they said I'd have to get them at the dealer, so which bushing are we talking about here? The rear shock bushings? Or the upper bushings on the front (the ones that go between the upper shock perch)??
  14. Dec 28, 2011 at 6:39 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No I'm still running the 1st gen Tundra 5100's with stock coils, but from all info i got the Eibach's will give a true 3" lift with the billies set at zero & remain within specs for alignment according to the REP I talked to...
  15. Dec 29, 2011 at 12:15 PM
    #35
    BlackSportD
    Los Angeles
    Edited into content in earlier post.
  16. Dec 29, 2011 at 8:38 PM
    #36
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Your problem isn't from shocks, if your still stock sprung in the rear, more than likely thats where your issues with lane dancing down the road are going to be, I've been running my 5125's with a 3" lift with flawless on/offroad performance
  17. Dec 30, 2011 at 8:56 AM
    #37
    BlackSportD
    Los Angeles
    Flipped the shocks and its much better.
    The 5125s are a 255/70 valving, IMO our lightweight truck should run the 170/60 IMO. I drive slow when offroading though and have had times when going fast the front 5100s can't seem to keep things buttoned down. Like zbaldo says below, the 5125s to clasp things down some, if one is into high speed running, I can see the advantage.
  18. Mar 5, 2012 at 9:52 AM
    #38
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    My 5125's are like my new bed firm but can take the beating.
  19. Mar 20, 2012 at 4:24 PM
    #39
    ckblum
    ckblum Well-Known Member
    Cam
    Chilliwack, BC
    Tacoma
    Bilsteins, Light Racing UCA's, Alcan's, Kragen HID's
    Are the rears two different lengths? What is different about them that they have different part numbers?
    Reason I ask is I think mine are on the wrong sides. Checking right now.
  20. Mar 20, 2012 at 4:31 PM
    #40
    ckblum
    Cam
    Chilliwack, BC
    Tacoma
    Well I literally just checked and they are backwards. Let's hope 15000km wasn't enough to wreck anything. Didn't do off road, service roads a few times.
