1st Gen Blown Head Gasket...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Moto2ndGen, Dec 22, 2020.
  1. Dec 25, 2020 at 8:29 PM
    #41
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    With head gaskets, the overheating is a symptom of the the gasket failure, not the cause. 250K miles and 24 years, that's a lot of time and miles. Any gasket, over time, will fail. Now, if you let your engine overheat because you ran low on coolant or oil, then yes, overheating will, or can be the cause.
  2. Dec 26, 2020 at 1:46 AM
    #42
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Well if that were correct every 1st gen Tacoma over 250k would have blown a head gasket. They dont just fail because 250k and age.
    I’ve got 368,000 and 24 years no head gasket failure.
    Pretty sure bad old acidic coolant is likely the culprit in OPs situation.
    I change my coolant, use Toyota red, dilute it with distilled water and haven’t ever over heated. Things don’t usually break unless there is something wrong. Cracked heads or over heating or bunk gasket or bad old coolant or electrolysis eating the aluminum. However age and miles alone, is no reason a head gasket that hasn’t been compromised should fail.
  3. Dec 26, 2020 at 7:11 AM
    #43
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Breaking news: even a non-disposable lifetime vehicle like a 1st gen Tacoma, still requires occasional maintenance and repairs.
