1st Gen Body Lifts, thoughts and opinions.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Royderjd, Oct 10, 2018.
  1. Oct 10, 2018 at 1:20 PM
    Royderjd
    Royderjd [OP] Well-Known Member
    Jonathan
    95 Tacoma 2.7L 4x4
    I have a '95 Tacoma with a 2" body lift and daystar leveling kit on it. I'm currently running 35s on my truck. i have very little rubbing issues with the main spots being the frame and the front bumper. I bought the truck with the lift already on it and I want to get rid of the body lift or got down to maybe a 1" body lift. I know getting rid of the body lift will probably require some work to let the tires clear where the fenders bolt up to the cab. How hard would it be to remove the body lift and what would I need to buy to accomplish this task? Replacing it with a 1" lift would be pretty straight forward.
    Any thought and input would be greatly appreciated. Thanks -JB
  2. Oct 10, 2018 at 1:31 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    How do you have 35's without tubbing the front fenders and chopping the body mounts?
    I should clarify: most people even with a 6" suspension lift can't fit 35's without doing at least some cutting...
    Crow_of_judgement likes this.
  3. Oct 10, 2018 at 1:38 PM
    Royderjd
    Jonathan
    95 Tacoma 2.7L 4x4
    Do I need to send pictures, the wheel offset I should assume helps. I did cut a few inches out of the inner fender plastic, but for the most part it just fit and works. :notsure:
  4. Oct 10, 2018 at 2:44 PM
    jbrandt
    Justin
    You don't NEED to send pics, but yeah, pics would help. :D
    What "leveling" kit do you have? I would venture it's more than just a simple leveling kit and more like an actual lift. Most people I've seen that fit 35's need to do a fair bit of cutting, and even wheel spacers etc... don't negate the need to cut, so honestly you'd be the first I've seen.
    The "pinch weld mod" is common (hammering the fender pinch weld down) but that's needed ever for most 33's.
    Here's what most people end up doing to fit 35's on a 3" lift. But even a 6" bracket style lift and I think there's still some cutting and tubbing that needs to happen.
    https://www.tacomaworld.com/threads/fitting-35s-on-3-suspension-lift.307596/
  5. Oct 10, 2018 at 2:54 PM
    Royderjd
    Jonathan
    95 Tacoma 2.7L 4x4
    Yeah I hammer down the pinch welds for good measure. It's a Daystar leveling kit, it lifted it 2.5 and 1.75 in the rear if I remember correctly, I end up replacing the spacers and UCA in the front with Fox 2.5 coil-overs and Camburg UCAs. If it wouldn't cost me an arm and leg to get some leaf springs shipped up to Alaska I replace the expedition leaf springs in the rear with some Deaver leaf springs. Then fab up some new shock mounts and mount up some 2.0 w/reservoir to the rears.
    jbrandt[QUOTED] likes this.
  6. Sep 29, 2019 at 8:42 PM
    CoalTrainTaco
    CoalTrainTaco Welker
    Aiden
    Nashville, TN
    2017 Super White SR5
    Fox 2.0 Coilovers MaxTrac Spindles TC Lighting Headlights Red Rock Roof Rack
    This is a long shot but worth the try....Where’d you get the 2” body lift at??
  7. Sep 30, 2019 at 12:22 PM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    +1 on this.
    I have a 1" 4crawler body lift on my 04 Dcab.
    Most on here don't like bodylifts. I haven't had any issues with mine. Stick to 1" and it will be fine.
  8. Sep 30, 2019 at 10:37 PM
    CoalTrainTaco
    Aiden
    Nashville, TN
    Did the 1” really make much of a difference appearance wise?
    I know the typical view on BL’s but I’m struggling to decide between a 3” or 1”.
    I’m currently running 33s with a 2.5” suspension lift. I would like to go higher without having to drop the $800+application on a 6”.
    Any recommendations?
  9. Oct 2, 2019 at 2:49 AM
    brs127s
    O'Fallon, MO
    I had a suspension lift.and was rubbing the mud flaps and the fram when the front wheels were turned. I added the 1" body lift and it no longer rubbed.
    CoalTrainTaco likes this.
  10. Oct 2, 2019 at 9:34 AM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    I'm running 2" BL with 2.5"/4" suspension lift. My opinion, it's perfect. 1" seems too much work and very little gain and 3" will just show everything up. I fabbed up my own bumper brackets, bed support and added gap guards. There's a gap between the hitch and rear bumper but with the back end sitting high, it doesn't bother me.
    Although, on my previous second gen, my only choice was a 1" BL and it was enough to make 35's clear but that was more of functionality rather than aesthetics.
    Taco critter likes this.
  11. Oct 2, 2019 at 12:10 PM
    CoalTrainTaco
    Aiden
    Nashville, TN
    I definitely agree with the 1" being too little for what you work for. I would love to do a 2" BL, I think it would be just what I'm looking for and enough to do 35's. However, they don't have one for my year (2003). It seems to only be a 1" or 3" with nothing in between....It looks like I might have to go with the 3" and grab some gap guards to go along with because I myself don't like the look of being able to see under the bed...Thanks for the input!
    By the way, was the BL something you were able to install yourself or did you take it in to get done?
  12. Oct 2, 2019 at 1:26 PM
    jbrandt
    Justin
    We can tell....
    :D
  13. Oct 2, 2019 at 3:42 PM
    CoalTrainTaco
    Aiden
    Nashville, TN
    Happen to have any photos from the side/rear?? Trying to get an idea of what I'd be looking at. Did you install yourself or have it done?
  14. Oct 2, 2019 at 5:35 PM
    CoalTrainTaco
    Aiden
    Nashville, TN
    How was the install process for you? Thanks for the photos!
  15. Oct 2, 2019 at 8:51 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Mine had a 3" body lift. I though it looked and drove like shit so I removed it. What a PITA.
  16. Oct 2, 2019 at 9:17 PM
    CoalTrainTaco
    Aiden
    Nashville, TN
    What made it drive like shit?
  17. Oct 3, 2019 at 8:55 AM
    oconnor
    oconnor Where am I?
    Midwest
    Maybe the tall spacers wear faster but the thing was loose, felt like the cab would move around in corners especially mid-corner ripples. Removing the lift and replacing with stock height bushings really tightened it up.
    CoalTrainTaco[QUOTED] likes this.
  18. Oct 3, 2019 at 10:50 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Recheck the bolts after driving for a short period of time. retighten as needed. 1" 4Crawler BL here. If you ever have to do any work on the transmission, BL's do make bolt access easier @ top of bellhousing.
  19. Oct 3, 2019 at 3:26 PM
    squarenut
    squarenut Well-Known Member
    russell
    FALLBROOK
    1995 single cab taco
    3" suspension lift. I had a taco with a 3" body lift and hated it.
  20. Oct 3, 2019 at 7:36 PM
    CoalTrainTaco
    Aiden
    Nashville, TN
    May I ask why?
