1st gen brakes suck. What improvments can be made short of the Tundra swap?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Backinblack03, Nov 26, 2019.
  1. Nov 26, 2019 at 12:52 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    How much weight are you hauling around ??
    I haul anywhere between 1000 pounds and maybe tow another 2000 .
    My stocks brakes work just fine .
    Are you looking for sports car type brake performance ?
    paetersen likes this.
  2. Nov 26, 2019 at 2:03 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Interesting, I can see that being able to happen. Hadn't dawned on me.
  3. Nov 26, 2019 at 2:05 PM
    cruiserguy
    Elijah
    SEKS
    Data! :D gotta cold spoon for me, I can't handle all of it:rofl:
    Awesome list on pad material grades hermano!
    Wagner makes a GG? No kidding
  4. Nov 26, 2019 at 2:22 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    data!
    cruiserguy[QUOTED] likes this.
  5. Nov 26, 2019 at 2:23 PM
    paetersen
    paetersen Well-Known Member
    I never understood the need to go with the tundra upgrade. I will never give up the ability to run a stock 15 inch rim. And my brakes are great, even hauling enough wood in the bed that I'm sitting on the stops. Went through everything, rebuilt calipers up front, new wheel cylinders, good pads, good shoes, parking brake working and adjusting as it should, drums adjusted correctly, parking brake used every time i get out of the truck, fresh fluid flush with good fluid.
    With a drum-in-the-rear setup the bulk of the customer complaints about crappy brakes that I see comes down to shoes needing adjustment. The 1st gen tacoma wants more shoe 'drag' than any other vehicle I've ever worked on.
    Then followed by siezed parts, old fluid, etc. Or someone put the autozone 5 buck brake pads on and wonder why they suck...
    1997tacomav6, CS_AR and Wyoming09 like this.
  6. Nov 26, 2019 at 2:48 PM
    jbrandt
    Justin
    *peer reviewed* data
    :D
    cruiserguy and CS_AR[QUOTED] like this.
  7. Nov 26, 2019 at 2:55 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Or your axle seals leak as bad as mine and all stops must be planned well in advance. :anonymous: I normally give 7-8 car lengths in front of me. Ehhhhhh
  8. Nov 26, 2019 at 3:06 PM
    Backinblack03
    Backinblack03 [OP] Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    Hauling a fiberglass camper cap. Empty bed for the most part. I guess I'm comparing it to the rental 4th Gen I had over the summer. Just touching the pedal in comparison would put me into the steering wheel. Rear parking brake bellcranks are 2 years old if I recall. Put them in just before the frame swap. Is there a procedure for bleeding the ABS modulator? I may look into that before winter really hits...
    Got the Powerstop Z36 (GG) kit 2 summers ago. Didn't improve much, IMO...
    cruiserguy likes this.
  9. Nov 26, 2019 at 3:19 PM
    agalloch07
    agalloch07 Well-Known Member
    I just bought a 2002 2.7 single cab 4x4 tacoma and the brakes work too well they feel like they are going to throw me through the windshield.
  10. Nov 26, 2019 at 3:24 PM
    02hilux
    Planet: EARTH
    PO did TBU and you didn't know it, lol
  11. Nov 26, 2019 at 3:33 PM
    agalloch07
    Could be but i doubt it, i bought it off an old lady who bought a new tacoma. My 97 4runner has the tundra brake upgrade that was done by the previous owner and it stops well but no where near as well as my new 02 taco.
  12. Nov 26, 2019 at 3:46 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Not to toss a screw into this thread's carb but not "all" 1st-gen brakes "suck". Over the long almost 19 years I've had this truck, those stock brakes have always performed very well, and have sometimes been flat-out impressive in accident avoidance. IMHO they will stop on a fucking dime.
    Hamer95USA likes this.
  13. Nov 26, 2019 at 3:47 PM
    1997tacomav6
    Denver
    You probably need a new master cylinder and brake booster with a flush.
    Stainless lines will help.
    I can lockup my tires easily
    Hamer95USA and cruiserguy like this.
  14. Nov 26, 2019 at 3:57 PM
    cruiserguy
    Elijah
    SEKS
    Lmaooooo I'm stealing that one! Right click save :rofl::rofl:
  15. Nov 26, 2019 at 4:00 PM
    #35
    cruiserguy
    Elijah
    SEKS
    True, agreed.....some people's 'data point is a disgrace to the forum'. I hear ya Brandt (seriously I do and I'm glad you're saying it, very valid):D
    jbrandt[QUOTED] likes this.
  16. Nov 26, 2019 at 4:01 PM
    #36
    cruiserguy
    Elijah
    SEKS
    :rofl:
  17. Nov 26, 2019 at 4:07 PM
    #37
    cruiserguy
    Elijah
    SEKS
    Was thinking about this the other day, and I remembered I had said that I couldn't see a way for that to make any difference, but the other day in my head it clicked. When we slam the brake pedal hard and fast that fluid needs to move hard and fast to the pistons right? I was thinking there's no way it could be a volume issue going through banjo bolt but maybe it is? I just had the thought just now typing, that some folks that do the TBU, they use hard lines to connect to caliper, and those hard lines that diameter is pretty darn small.... And they run longer than the bolt and it's diameter....i dunno man, I can't think of something to convince me either way fully yet
    CS_AR[QUOTED] likes this.
  18. Nov 26, 2019 at 4:17 PM
    #38
    cruiserguy
    Elijah
    SEKS
    No kidding? That's where their big push on continuous improvement came from? Amazing. They are an incredible company with an even more incredible story and history. Deming, that's cool to know
  19. Nov 26, 2019 at 4:24 PM
    #39
    1997tacomav6
    Denver
    Running green stuff EBC and these work excellent
    GG rating .45
    cruiserguy and CS_AR like this.
  20. Nov 26, 2019 at 10:12 PM
    #40
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I just put the Power Stop Z36 pad and rotor kit in my truck about a week ago and followed the break in procedure and they have been working awesome. I also have the stainless lines installed and flushed out the brake system when I did the brake lines.
    The brakes saved my bacon when an idiot did a u turn in front of me right at the last minute, I think I was a foot away from hitting him when he pulled that stunt.
