1st Gen buying advice, 6 vs 4 cyl?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Daburglar, Oct 24, 2013.
  1. Oct 26, 2013 at 8:48 PM
    Daburglar
    Daburglar [OP] Member
    Going to go look at a v6 auto extended cab tomorrow, it has a 2inch lift and 33 inch tires. I don't really know much about lifts is there anything i should look for/inspect? Also, I looked up the vin and it said it was auctioned off as having frame damage, kinda seems like a big deal, wasn't mentioned in the ad at all though. Anything I should look for?
    After comparing the the v6's and 4's more I think that im now maybe open to both possibilities like some of you said when the right one comes along whether 4 or 6 it'll be the one.
  2. Oct 26, 2013 at 10:02 PM
    Daburglar
    k thanks bass i'll be sure to snap some pictures while I check it out, and I have heard of the Toyota recall that you mentioned I should read up on it before I check it out tomorrow.
  3. Oct 26, 2013 at 10:55 PM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Exactly!
    I have a feeling everyone who's saying that the 2.7 has plenty, or even adequate power, has got to be a flatlander
    To have to downshift on the interstate to maintain speed on such minor grade increases that, before hand, you barely realized there was change in gradient at all, to me, just wasn't acceptable
    I didn't buy a truck for speed either; but, I did have an expectation that whatever I buy should be able to take passes better than my x-girlfriends 89 Honda Civic that had dragging brakes
  4. Oct 26, 2013 at 11:10 PM
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    The 2001 toyota echo I had for a few months this year as a commuter car was an absolute rocket compared to my truck. Though it weighed as much as a gokart, it was adequately powered for what it was and an absolute blast to drive.
    The right one won't be a 4cyl. Seriously, this is coming from someone with a 4cyl a state over from you. I'm not some 6cyl elitist, do it right the first time. Also, check the frame of that one you were going to look at (I think you said it was 6, right?) like someone else mentioned. Look for repairs to the frame as well. And as far as the lift goes, check and see if its a spacer lift. Google for pics of these on strut assemblies, and inspect rear too... easy to find pics. You would probably want to avoid if so.
  5. Oct 26, 2013 at 11:35 PM
    flatblack
    CDA
    "Round 1... ... FIGHT!"
  6. Oct 27, 2013 at 12:33 AM
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    Let me rephrase since you're apparently quite touchy when it comes to spacer lifts (I've seen your name in every spacer lift thread I've read since joining).
    If you learn that a truck has frame rust and is being sold by a dealership omitting all information pertaining to this, you'll probably want to avoid it.
    Now, maybe you can explain to him the difference between an in coil and above coil spacer, providing pictures of your truck wheeling and defying the whole bottoming out thing while ferverously masturbating.
  7. Oct 27, 2013 at 12:42 AM
    scocar
    scocar Patron of the Farts
    This. Automatic in the mountains makes it pretty clear.
  8. Oct 27, 2013 at 1:05 AM
    flatblack
    CDA
    "Round 2... ... FIGHT!"
    :duel:
    :popcorn:
  9. Oct 27, 2013 at 2:40 AM
    hikesnp
    hikesnp Member
    Todd
    Axton, VA.
    98 4x4
    I have a 2.7 witch i take to the mountains on a regular basis. I drive about 175 miles each way and it hauls my payload great. It also averages 26 mpg-in 2wd
  10. Oct 27, 2013 at 7:43 PM
    Daburglar
    Here's the link to the one I saw today: http://www.ksl.com/auto/listing/667685?ad_cid=2
    I went with my buddy to check it out and it seems like a fairly low price for the deal, as stated above the VIN showed that it was auctioned off as having frame damage (didn't specify) but me and my friend didn't notice anything particular when we inspected it just the normal rust as most Tacomas, and we didn't see any repairs that were made to the frame itself.
    We asked the guy who was selling it, he's actually a really nice mormon guy who is selling it for his son who's away at school and doesn't need the truck about the frame. He said his son never really knew about that as the VIN showed it happened over 6 years ago.
    Im not really too knowledgeable on lifts so here's some pics I took of that:
  11. Oct 27, 2013 at 7:48 PM
    Daburglar
    I talked him down from $5500 to $5000 too this is a good deal at least to me it seems, ive been looking tacomas that run $1,000- $2,000 more for basically the same miles and quality for weeks so im gunna do im pretty sure.
  12. Oct 27, 2013 at 7:50 PM
    Daburglar
    Here's from the ad (I asked him to take it off, so in case it gets deleted..)
  13. Oct 27, 2013 at 8:07 PM
    Daburglar
    Felt great honestly, low noise while driving super easy to switch in and out of 4L, 2H, 2L.
    The Belts were super tight and everything worked well, AC was cold in an instant. There was a slight noise maybe with a power steering pump we thought when we opened the hood while it was running, but not totally sure what it was seemed minor though.
  14. Oct 27, 2013 at 8:39 PM
    Daburglar
    ....Say if I ever wanted to lower the truck how difficult would it be to remove those spacers, are they something that are on the front and back (since I can't remember) and if not what would I have to do to the back?
