1st gen CA smog legal intake?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vicstacoma, Apr 5, 2013.
  1. Apr 5, 2013 at 12:39 PM
    vicstacoma
    vicstacoma [OP] Well-Known Member
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Air raid cold air intake, procomp 7089 16x8 wheels, bf goodrich all terrain ko 265/75r16. Toytec 3" lift kit. Power slot rotors with posiquiet ceramics pads. Diff breather mod. LR Upper Control Arms.
  2. Apr 5, 2013 at 2:41 PM
    Geosh
    Geosh Why yes, I AM a rocket scientist.
    Chandler, AZ
    '03 PreRunner DC, 3.4L
    I used to. I just sold it 2 weeks ago. I think I still have the sticker stuck to the inside of my hood (from the original owner) that shows it is CARB ok too.
  3. Apr 5, 2013 at 5:54 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    My AEM Brute Force is legal and dry flow filter. Much better then the oil K&N.
  4. Apr 5, 2013 at 6:37 PM
    vicstacoma
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Ok thanks. I think I'll go ahead and order it and take off the airaid intake I have since i won't pass smog.
  5. Apr 5, 2013 at 8:40 PM
    License2Ill
    License2Ill Ain't one for poetry & prose
    Ian
    AZ Über Alles
    04 TRD 4x4
    SC'd Double cab 5 spd
    Just keep your stock airbox for cheap insurance.
    My buddy w/a CAI went to three different smog places and all rejected to pass him because it was "modified". Might save you a headache.
  6. Apr 10, 2013 at 6:53 AM
    PRBond
    PRBond Well-Known Member
    Patrick
    Columbus, OH
    04 TRD PreRunner
    3" ToyTec suspension kit, AEM Air Intake, Uniden 510 CB, 265 X 75 X 16 BFG AT's
    I have the same one on my truck and never had any problems with smog. I love the way my motor sounds with it. : )
  7. Apr 10, 2013 at 12:55 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    In Cali you want to have a CARB sticker
    that can be affixed somewhere in the engine bay.
    If it doesn't come with CARB approval...
    it can fail the visual test.
    I've had a K&N fipk installed since 2001
    never had a issue passing smog.
    I also still have muh oem air box (w deck plate mod)
    tho' I really haven't found any real reason for swapping back.
    Maybe once when I was headed for a trail that had many known
    water crossings.. but besides that instance... never
    Fact is... any intake you install will likely lose a coupla' HP...
    yer not going to feel that at the pedal tho'
    IMO... the K&N does increase throttle response...
    but it is minimal... and the intake sucking noise
    is what thrills people most.
    I have never had issue with muh fipk intake syst.
    Never fubar'd the MAF from over oiling.
    I think most folk compare the fipk element
    to the K&N "drop in" element for the oem air box...
    IMO the drop in element can be problematic.
    and is this element that everyone tends to over oil.
    Thus saturating the MAF and causing throttle issues.
    It doesn't destroy the MAF usually...
    and a quick cleaning (oil film removal) usually puts it back on par.
    But I still refuse to use that drop in element.
    For the oem AB... I just stick with the oem fuzzy filter.
    Alternative...
    You can get the same performance of a aft. mkt. intake
    by simply modifying your oem air box.
    Installing the deck plate mod will give you the same sound.
    Yeah yer still likely to lose a coupla' HP
    But if a performance sound is what yer after...
    The deck plate mod is the least expensive...
    and basically offers the same throttle response
    and suction noise as a full intake syst.
    And with spending less money.
    That said...
    still like muh FIPK intake syst.
    Because I haven't bought a filter element since muh junk was new.
    The last fipk element became dry rotted after 12 years use.
    K&N sent me another to replace the original... no charge.
    Their lifetime warranty is for real ;)
    Many folks have hoped to gain performance by installing
    aft. mkt. intake systems.
    But IMO... that's a waste of money
    unless the lifetime filter element might appeal to you
    and saves you money over it's lifetime of use.
    * if you install the DP to the oem AB...
    I recommend closing that when conducting smog tests.
    out of sight, out of mind, works best for smog techs looking to make mo' money.
