1st Gen Carrier Bearing Squeal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mauricefm, Nov 14, 2019.
  1. Nov 14, 2019 at 7:36 AM
    Mauricefm
    Mauricefm [OP] 00MoeTaco
    Moe
    Athens GA
    2000 Tacoma PreRunner SR5 V6
    Pioneer, bazooka rs10, kenwood / Rockford fosgate amps, Polk audio 6.5 in the doors/rear
    So much stuff in here; timely to search. Apologies if this question is answered somewhere else..
    I replaced the carrier bearing at ~108k miles due to squealing. I'm having the same issues again at 160k. It squeals terribly while coasting above 25mph.
    Is this normal wear for a 1st Gen preunner (3.4L, SR5, automatic)?
  2. Nov 14, 2019 at 7:40 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    No, that is not normal. I've had failed CBs, non where squealing. Are you sure it's not something else?
  3. Nov 14, 2019 at 7:44 AM
    Mauricefm
    Moe
    Athens GA
    I'm sure that it's the CB as the symptoms are the same. "squeal" may be a poor description.
