1st gen Clutch Kit Recommendations?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hamsmash, Mar 28, 2023.
  1. Jul 9, 2023 at 5:17 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Very true. I’ve smelt mine several times in tight/precarious spots wheeling trying to finesse it to get power without wheel spin, when in lived in Seattle and would be stuck on hills in stop and go I’d just drop it into low range and tick up the hill to spare my leg and the clutch
  2. Jul 9, 2023 at 5:21 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Feel like changing your clutch let one of your friends make a parts run of a few miles.
    I am not sure it might have been the stock Clutch 125,000 miles I was having no problems . One 10 mile round trip it was done. His own 4 Runner was a manual.
    Laxtoy[QUOTED] likes this.
  3. Jul 9, 2023 at 6:01 PM
    Laxtoy
    Maltby, WA
    Lol, that’ll do it.
    Bivouac likes this.
  4. Mar 3, 2025 at 11:00 AM
    OCPaisa
    OCPaisa Well-Known Member
    Peter
    O.C.
    2004 Toyota Tacoma 4x4, MT
    OE 17" 4runner TRD Pro wheels. 265/70/17 BFGoodrich KO2
    Anyone know of a good shop or person on here that can replace the clutch on a 2004 Tacoma? I'm in the I.E. area.
  5. Mar 3, 2025 at 2:02 PM
    OCPaisa
    Peter
    O.C.
    Do you have a part number for the flywheel? Have a V6 2004 Tacoma Tacoma MT that my old man left us after passing away during the covid pandemic.
    I'd like to take care of it mechanically and after 165K miles on it, don't think he ever changed the clutch. It's having issues with the clutch pedal and gets stuck sometimes not being able
    to go into gears. Not trying to get you to diagnose the issue, just trying to purchase as many correct components to take to a mechanic. Rather replace as much as possible while the person has it on the lift.
  6. Mar 30, 2025 at 10:17 AM
    hamsmash
    hamsmash [OP] Well-Known Member
    Sacramento, CA
    00 Tacoma 3.4 4x4 5spd
    For my 2000 V6, I used part number 13405-62030 for the flywheel. Should be the same for a 2004, but double-check first.
