1st Gen Coilbucket Gussets
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Reh5108, Apr 16, 2021.
  1. Apr 30, 2021 at 6:15 PM
    Hamburgler_101
    Hamburgler_101 Well-Known Member
    Aidan
    Ramona CA
    2001 Tacoma 4WD Prerunner
    4WD Conversion
    Reh5108[OP] likes this.
  2. May 1, 2021 at 8:47 AM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Ryan have you had a chance to check out the 3rd gen 4runner measurements yet?
  3. May 1, 2021 at 9:06 AM
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I have not.
  4. May 6, 2021 at 5:05 PM
    Reh5108
    Idaho
    3rd Gen 4runners look to be different other than just the bolt holes. Made a paper template for the driver side and the UCA holes seem to be higher than the Tacoma.
    AssQuake likes this.
  5. May 13, 2021 at 12:53 PM
    Reh5108
    Idaho
  6. May 15, 2021 at 11:51 AM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
  7. May 8, 2022 at 7:32 PM
    Reh5108
    Idaho
    Are you all still interested? Cut 6 pairs today on my neighbors plasma table. Still need to figure out boxes and packaging but the cost will be significantly less that what it would be from the laser cutter. 20220508_190725.jpg
    Speedytech7 and BYJOSHCOOK like this.
  8. May 8, 2022 at 7:39 PM
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    Yep, I'm still good for a set
    Reh5108[QUOTED][OP] likes this.
  9. May 8, 2022 at 7:45 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
  10. May 8, 2022 at 8:48 PM
    Hamburgler_101
    Aidan
    Ramona CA
    4WD Conversion
    Yes, I’m still interested in a set.
  11. May 9, 2022 at 7:08 AM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    Is it too late to get in on a set of these?
  12. May 9, 2022 at 8:20 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I'd be in for one too
  13. May 9, 2022 at 10:39 AM
    Reh5108
    Idaho
    Give it a week for @JoeyWales and @vonellis to respond.
    Wulf likes this.
  14. May 21, 2022 at 2:19 PM
    Reh5108
    Idaho
  15. May 22, 2022 at 9:36 AM
    #35
    Arman Bagdasarov
    Arman Bagdasarov armbag
    2001 4x4 Tacoma
    Camburg UCA, King coil overs, Fox Shox, Deaver springs, BAMF sliders & LCA Skids, Relentless Skids. Lights on lights on lights
  16. May 22, 2022 at 7:57 PM
    #36
    Reh5108
    Idaho
    I'll post up when I have another batch available!
    Laxtoy likes this.
  17. Jun 8, 2022 at 10:22 AM
    #37
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    Ryan,
    Can these gussets be welded in with the fender still in place?
  18. Jun 8, 2022 at 10:28 AM
    #38
    BYJOSHCOOK
    Josh
    Check Out My Builds
    According to the first page yes only coilover, brake line bracket and UCA need to be removed
    btu44[QUOTED] likes this.
  19. Jun 8, 2022 at 11:20 AM
    #39
    Reh5108
    Idaho
    Yes, no need to remove the fender. If you want to weld the backside you may need to remove some parts from the engine bay. I was not overly concerned with it though.
  20. Jun 8, 2022 at 1:23 PM
    #40
    IEatPieLeftHanded
    IEatPieLeftHanded IEatPieLeftHanded
    Michael
    SoCal
    2000 Tacoma 3.4L 4x4 Manual
    Interested in a set for a 3rd Gen 4Runner
