1st Gen Computer Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikePutnam, Aug 26, 2009.
  1. Aug 26, 2009 at 1:04 PM
    MikePutnam
    MikePutnam [OP] New Member
    Los Angeles
    02 Prerunner SR5 2.7 2x4
    I have a 2002 Tacome Prerunner with 167k mikes on the original 2.7 liter engine. Cylinder #2 is not firing. A master mechanic told me he thinks its the computer. Anyone ever come across this problem? Anyone know where I can buy a computer?
  2. Aug 26, 2009 at 1:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW. First, don't listen to him. There are several things that could go wrong well BEFORE the computer.
    We are going to need some more information first.
    What have you or the master mechaninc done to the motor for trouble shooting?
    Have you replace the plugs?
    Have you swapped out the coil pack with another one?
    Have you done a compression test?
    Have you change any plug wires?
    Is there a CEL (Check Engine Light)?
  3. Aug 26, 2009 at 1:21 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    yeah,what Ben said .
  4. Aug 26, 2009 at 3:25 PM
    MikePutnam
    Los Angeles
    The mechanic replaced spark plug, swapped coil, did the compression test, changed wires. CEL light comes on intemittently, but doesn't give a code to what the problem is. The mechanic figured try replacing the computer and see what happens.
  5. Aug 26, 2009 at 3:29 PM
    98tacoma27
    Ben
    Not Beech Creek
    I have yet to see a computer go bad. When he swapped the coil, did he just test it then swap it back? Or did he leave them swapped?
  6. Aug 26, 2009 at 3:37 PM
    98tacoma27
    Ben
    Not Beech Creek
    What are the code(s)? If number 2 is missing, you should have a P0302. There could be others.
  7. Sep 1, 2009 at 6:26 PM
    98tacoma27
    Ben
    Not Beech Creek
    Update???
