1st Gen Crew Cab with Manual?
Discussion in '1st Gen. Tacomas (1995-2004)' started by drewdat, Aug 30, 2010.
  1. Aug 30, 2010 at 9:43 PM
    drewdat
    drewdat [OP] New Member
    Quick question... was it possible to get a Crew Cab with a Manual Transmission?
    I haven't been able to find any on Ebay, C/L or Autotrader. I'm starting to wonder if I can find a 1st Gen Double Cab TRD 4X4 V6 Manual Tanny...
    Thanks!
  2. Aug 30, 2010 at 9:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    1st gen double cabs only came with autos.
  3. Aug 30, 2010 at 9:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    A friend of mine claims to have seen one. Supposedly the owner special ordered it that way and had to be very persistent to get Toyota to build it.
    So realisticly, you're not gonna find one.
    Too bad really, that would be an awesome configuration.
  4. Aug 30, 2010 at 9:57 PM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    There are some out there. People mod them. Pull the auto out and drop a 5 or 6 speed in it.
  5. Aug 31, 2010 at 3:24 PM
    smbundy13
    smbundy13 Well-Known Member
    Scott
    Birmingham
    just curious how difficult of a swap that would be? the only complaint after about a month with the truck is the auto tranny seems to sap a lot of power from the motor.
  6. Aug 31, 2010 at 7:17 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The classic writeup on this swap was hosted for years on Junglecode. That was the single best overview for what's involved. Unfortunately, the documentation went MIA. It was salvaged last year and is now archived over at CustomTacos:
    http://www.customtacos.com/forum/showthread.php?t=137151
  7. Sep 1, 2010 at 4:58 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    You should def do a swap! V6/manual combo is very nice.
  8. Sep 1, 2010 at 12:16 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    I always thought that was a downfall that they didn't build the first gen dbl cabs in a manual. I would have considered them had they been offered in a manual.
  9. Sep 1, 2010 at 2:27 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Agree - really turned me off to them though I'd love to have one. You can get 2nd gen short bed DC's in 6 spd manual by special order, they must have listened to their customers.
