1st Gen. Dash vibration
Discussion in 'Technical Chat' started by Clank, Jul 6, 2009.
  1. Jul 6, 2009 at 11:06 AM
    Clank
    Clank [OP] Member
    Connecticut/Texas
    00 PreRunner 2WD
    Flow Master Exhaust, K&N Intake
    The noise is annoying, I've heard it on a couple other 1st Gen.'s too... Anyone know any proven ways to eliminate it? I'm thinking about sliding a strip of rubber underneath, but that might require taking the dash out. Obviously I'd like to be as unintrusive as possible to minimize frustration. Thanks!
  2. Jul 6, 2009 at 11:19 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    good luck
    this is a fairly common occurrence and im not sure anything is proven over time to permanently fix the problem...my solution was to put a hat on top of the passenger side dash...that seems to work
  3. Jul 6, 2009 at 3:50 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Mine disappeared since they "re-framed" it.....I went so far as to yank the glove box and drag a magnet through crevices thinking I must have "floated" something out of the box..
    They did not put new cab mounts but did use new bolts...If this helps...
    Snoope
