1st gen differences?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nd4spdbh, Oct 7, 2013.
  1. Oct 7, 2013 at 9:15 PM
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Alright tacomaWorld.... first off. I did some searching and couldnt find anything real conclusive.
    Just wanted to know if there is a list of differences over the years of the 1st gen.
    At the moment we have a 04 Trd xtended cab 2wd and its been a damn good truck... but i want one of my own and am looking at a 00 TRD 4wd xtended cab... and was wondering if there are any signicant differences as far as motor / running gear.
    I really dont think there is, i have been around the toyota world for some time and the good ole 3.4 i dont think has changed since 95.5 haha.
    Anyways thanks!
  2. Oct 7, 2013 at 9:19 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  3. Oct 7, 2013 at 9:21 PM
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    Leaf springs are shorter on 97-98 i think.
    My o3 came with a factory installed ice cream dispenser, and eject for the co dog seat. both have come in handy.
    That is all i got.
  4. Oct 7, 2013 at 9:21 PM
    nd4spdbh
    SoCal
    so it looks like possibly a different frame? or is it just due to the slightly different exterior that the truck is longer?
    EDIT- and btw... HOLLY SHIT BALLS quick responses. thanks guys!
  5. Oct 7, 2013 at 9:31 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    98-00 have 3" longer front frame horns. You can just cut em off and weld in new end plates with tapped holes
    Is motors are the same if they are both v6. Same gear boxes too.
    Very small changes where made through the years.
  6. Oct 8, 2013 at 8:09 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Drive train didn't change except for the manual hubs (no longer available in 2001) and manual vs push-button transfer case.
    The motor itself change over the years, since 95 had distributor.
  7. Oct 8, 2013 at 10:06 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    95.5-97 had the shorter rear leafs
  8. Oct 8, 2013 at 7:33 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    The early 3.4s are harder/more complicated to supercharge. Sorry, I don't know specifics.
  9. Oct 8, 2013 at 7:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    only 95 and 96s won't SC. The ECU's retard the timing causing a major loss in power.
    97-04s are good to go. You can swap a ECU from a 97 usually into a 95-96 and be fine.
    leafs shorter in 95-97. same length as pre tacomas. 98-04s are 3'' longer.
    5vz didn't change at all through the years other then a few getting rid of real throttle cable and some had EGR. early ones also had 1 cat instead of the 2 in 98-04s.
    2rzs were still offered in the earlier tacomas but changed to 3rz quickly which did have some differences but not many.
  10. Oct 10, 2013 at 9:18 AM
    nd4spdbh
    SoCal
    I am looking at a nice 97 5speed 4x4 with the 2.7 4 banger. anything i should look for in particular?
    Also what year did yota introduce the ADD over the factory manual hubs?
  11. Oct 10, 2013 at 9:32 AM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    About the only thing to look out for on the 2.7L is if the valve clearance is in spec. Also on the pre 01 2.7L they had a tendon to crack the exhaust manifold. This was changed on 01-04 2.7L to more of a header design and should eliminate the problem.
  12. Oct 10, 2013 at 9:41 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    check the frame. LBJ, Tie rods, steering rack, U joints, motor oil, tranny fluid, brake fluid and coolant levels.
    ADD was introduced with the tacoma in 95. If its not manual hubs. Its ADD. Transfer case operation did change from the mechanical J shift to the electronic push button.
    also the actuator for ADD changed form Vacuum operation to electronic around 00-01 i believe. Vacuum is a bit more reliable as the actuator has been know to fail on some that are electronic. Yours will be vacuum im sure and a J shift most likely.
  13. Oct 10, 2013 at 4:46 PM
    nd4spdbh
    SoCal
    awesome. and one last thing was it the 97 year models that the 2.7L 3RZ-FE moved away from a distributor?
  14. Oct 10, 2013 at 4:57 PM
    tan4x4
    Rick
    Folsom, CA
    I think '97 is the last year for distributor, but the change-over could have been made late in the '97 year. Easy to see it, if you look under the hood.
    ADD has been available since '95 as an option, until 2001, when manual hubs were no longer offered, and ADD was standard.
  15. Oct 10, 2013 at 7:10 PM
    nd4spdbh
    SoCal
    i had the guy send me a pic.. definitely not a distributor.... 2 coil packs on the side of the motor. which goes along with the wikipedia article saying that 97 was the year they went away from the cap n rotors.
    Also it has manual hubs, which id prefer... less wear on the cv's and less parts to get rotating.
  16. Oct 11, 2013 at 6:18 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    This is false... I have an 04 with a 2rz. The 2rz went away the same time the 3rz did (now the have the 2tr, still a 2.7l)
    Not that it's relevant to the OP. Only other thing that hasn't been mentioned yet is that there was a minor face lift in 98 and again in 01
  17. Oct 11, 2013 at 7:36 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    interesting. So wa the 2rz a 5 lugger motor and 3rz for 4x4s?
  18. Oct 11, 2013 at 7:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. Oct 11, 2013 at 7:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :laugh:
    that sleep musta payed off.
  20. Oct 11, 2013 at 8:15 AM
    MowTaco
    Kansas
    Yup, that's the only reason I got a 5 lugger. I wanted the 2.4 for fuel economy (which was a little disappointing and I wish I would've at least gotten a 4x4)
    Man, 2 wrongs in a row. Get your shit together Monte!
