1st gen differences?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nd4spdbh, Oct 7, 2013.
  1. Oct 11, 2013 at 8:26 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I know. dropping the ball.
    and that makes sense..yea not much in gas savings there haha
  2. Oct 11, 2013 at 8:28 AM
    scocar
    scocar hypotenoper
    So what is the option specificity? I have never seen this conclusively defined. I have SR5 TRD 01, and mine is J. I test drove others I swaer of the same spec but were I. Maybe I am on crack and they were 02 or even 03.
  3. Oct 11, 2013 at 8:29 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Sometime after 99, exact year not confirmed and frankly maybe even before, the extra cab rear drive shafts start to show up with smaller u-joints in the Double Cardan (CV). They can be identified by "outside" c-clips.
    Not saying they are not up to the job, just saying.
  4. Oct 11, 2013 at 8:30 AM
    scocar
    scocar hypotenoper
  5. Oct 11, 2013 at 8:31 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i think it was auto trannies vs manual mostly. But i think you could just pick if you wanted a J shift or electronic. I have seen both in just about every combination of packages.
  6. Oct 11, 2013 at 8:33 AM
    scocar
    scocar hypotenoper
    Everything I test drove was manual. Fuck auto.:D
    It's weird, because they are both on-the-fly, so why would they bother designing and manufacturing 2 systems? How is one more desireable than the other?
  7. Oct 11, 2013 at 8:36 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yea, that whole transfer case thing is like the "Low Fuel Warning Light". Seems to be hit and miss across the board.
  8. Oct 11, 2013 at 8:38 AM
    scocar
    scocar hypotenoper
    OMG I have the low fuel light AND the low wiper fluid light! That must be why I have a J shifter. Obviously.
  9. Oct 11, 2013 at 8:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ill take a J shift over push button any day. two less electronic actuator to fail. And they do, both the ADD actuator and T case actuator can fail. Like 400 bucks for a new one.
    but some like the convenience i guess of just pushing a button..haha
  10. Oct 11, 2013 at 8:41 AM
    scocar
    scocar hypotenoper
    Yeah but vaccum lines can fail too. I do agree though, I prefer more mechanical and less electrical in all systems. Yay 01 throttlebody and no ABS! Woot!
    Oh, and because ATRAC LOL.
  11. Oct 11, 2013 at 8:43 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea..easier and cheaper to have 4' of tubing in the truck then another 400 actuator you have to drop the diff tube to replace..haha
    i own both..granted i don't wheel the one with electronic stuff....yet..
  12. Oct 11, 2013 at 6:11 PM
    nd4spdbh
    nd4spdbh [OP] Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Thanks for all the info guys.
    I hate to say it but the little gem i found has two things i am not easily over looking..
    1. no abs.
    2. to a much bigger extent no passenger air bag. :mad:
  13. Oct 11, 2013 at 6:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    eh..abs sucks.
    airbag..yea..mine doesn't either. Oh well.
  14. Oct 14, 2013 at 3:18 PM
    nd4spdbh
    SoCal
    Hey guys I found an 02 access cab 4x4 v6 with the 5 speed. What kinda of mpg can I expect on the hwy. And what's the deal with 2000+ getting a different axle ratio?
  15. Oct 14, 2013 at 3:31 PM
    #35
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    up to 02 were throttle by cable, then 03/04 were throttle by wire
  16. Oct 14, 2013 at 4:11 PM
    #36
    scocar
    scocar hypotenoper
    probably about 18-20 mpg
  17. Oct 14, 2013 at 4:20 PM
    #37
    Blackdawg
    Monte
    Wyoming/St. Louis
    wut?? :der:
    wasn't a different axle ratio..axle ratio has to do with mainly your drive train.
    since yours is a 4x4 V6 5 speed. It'll most likely have 4.10s.
    hwy will be around 17-22 depending on how your drive, where your driving and gas.
  18. Oct 14, 2013 at 5:21 PM
    #38
    nd4spdbh
    SoCal
    Assuming they changed from like a 3.73 to 4.10's? how did that effect MPG?
  19. Oct 14, 2013 at 5:25 PM
    #39
    Blackdawg
    Monte
    Wyoming/St. Louis
    3.93s came in prerunner. All 4x4 V6s manual pretty much came with 4.10s. 4 banger manuals came with 4.30s and 4 banger autos came with 4.56s sometimes.
    High gear ratios means less strain on the motor. So usually better mpgs.
    If you want to know what your truck came with. Use this sheet and the code found in the drivers door
    https://www.dropbox.com/s/6iidyyk5s3k4k73/All_Toyota_Truck_Axle_Codes.pdf
  20. Oct 14, 2013 at 9:29 PM
    #40
    nd4spdbh
    SoCal
    thank you for the info!!!
    alls i know is in the case of my 2500hd chevy with 4.10's i get 12mpg vs my buddy with the same truck with the 3.73 gears getting 16-17..... 12mpg B L O W S!
