1st Gen. "DIY" and "How To" Thread: Compiled list of helpful links
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, May 29, 2010.
  1. Mar 18, 2015 at 12:45 AM
    #221
    Far12
    Far12 Active Member
    Oregon
    97 Tacoma 3inch lift
    LCE header 32x11.50 Maxxis Bighorn Tires Ultra wheels Skanda seat covers
  2. Mar 20, 2015 at 11:17 AM
    #222
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  3. Mar 22, 2015 at 6:41 PM
    #223
    tacotay99
    tacotay99 Well-Known Member
    Montucky
    Many to come
    Sweet thread!!! I'm in...
  4. Mar 22, 2015 at 9:00 PM
    #224
    nxrunner
    nxrunner Well-Known Member
    Nick
    Lafayette La.
    2015 Tacoma Double Cab 6 Speed
  5. Mar 22, 2015 at 9:22 PM
    #225
    taroy1
    taroy1 New Member
    95 Tacoma SR5
    ktmusa8 likes this.
  6. Mar 24, 2015 at 7:22 AM
    #226
    little bear
    little bear Well-Known Member
    Barry Hobson
    Canadian, Texas
    silver streak 2017 Tacoma trd sport 4dsb 6sp MT
    Black badges, TRD pro grill, clazzio seat covers, falken wild peaks AT3W 265 70R17, Fuel Trophy wheels, taco tunes 10" sub and Jl Audio all around speaker upgrades, dynamat doors and interior, Meso's interior lights, gasshole, waterproof led bed lights, headstrong progressive leaf pack, bilstein 5100's with OME 887 coils, ecgs bushing, nfab nerf bars, cbi t3 aluminum bumper
    Wow, That's a ton of info
  7. Apr 17, 2015 at 4:43 AM
    #227
    Tonka
    Tonka Pro-Darwinism
    Taylor
    America's Basement
    14 DCSB prerunner 04 AC 4x4 TRD OR. '16 DCSB 4x4 TRD OR
    '04 265/70R16 Dueler A/T, Softopper, Bilstein 5100's, Toytec AAL, DIY Satoshi, Midland CB, ARB front. Self fabb'd rear bumper. Smittybilt X20 winch '16 custom car grill, Cooper ST Maxx
    Im sure this has been touched on somewhere here but I have a DIY remedy for a bed mat if you are cheap like me and have a local Tractor Supply or similar store. I purchased 6 ft of 1/4" horse stall mat and cut it to length.. cost about $30 to make it and just as effective. it is 4 ft wide so it doesn't cover the entire bed but close enough. and no I dont have pictures. you can use your imagination though!
    http://www.tractorsupply.com/en/sto...t-rolled-rubber-1-4-in-thick-sold-by-the-foot
  8. Apr 17, 2015 at 10:11 AM
    #228
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Thanks for the DIY video man, I'm watching it now!
  9. Apr 27, 2015 at 8:27 AM
    #229
    cisskow
    cisskow New Member
    Hi all new hear and grateful to find some support and if possible add to the growing data base of info.
    Current issue, how it all started (my buddy talked me into this swap but is so busy now, and I need my rig back, so I'm struggling to find answers)
    1 Im doing a swap, into my 88, with the 2rz.
    what I have so far, rebuilt (not done with re-assembly, have questions about setting timing, have manual but need confirmation on all, as we all know 1 wrong setting will make a mess) 2rz, with a 2000 head ( old head was cracked) ecu and wire harness out of a 2000, bellhousing to mate the engine and tranny.
    Still need a starter, pressure plate, and some solid info on the oil pan issue, which is the best for performance vers investment as I'm getting many different suggestions and application ideas that now I'm lost, opinions very a lot, back ground on set up.
    This 2.4 is going into a 88 4x4 long bed, I guess my old oil pan won't work because of my front steering components and or the straight axle on the 88?
    Other unpleasant surprises, my buddy said this swap was easy, I asked any questions, he just said no problem, yada yada, anyway now I found out my motor mounts in fact won't line up with the 2rz's (as he said they would) i'm like 2 1/2 inches off, (forward) not found of cutting off mounts, e.t.c also guess I can use my ole crank pulley, which means now my power steering and alt pulleys need modded? Or is there a configuration that will marry the 2 i.e. serp belt that can run a V pulley, e.t.c. or a crank pulley swap that will still run oil pump but has the V belt set up?
    Also need a tutorial on this swap, I'll keep browsing but a few links would be great.
    Of course any and all input will help me to get this 2rz into my 88 is appreciated.
    Thanks
  10. May 1, 2015 at 4:51 PM
    #230
    TacomaKeys
    TacomaKeys Member
    Key Largo, FL
    02 dbl. Cab 3.4l
    Maguires back to black, after you get it really clean with soap and water works on all plastic not just black plastic
  11. Jul 24, 2015 at 11:06 PM
    #231
    RoDan-55
    RoDan-55 New Member
    '95 SR5,
    Sound
    I need to see a diagram, or knowledgeable person out there to answer, for the inside clutch assembly from piston to pedal has a bolt that slides through the 2 sides. A cotter pin holds the piston/pedal together. Now comes my quandary and search to see if there is also a spring attached near the cotter pin to pull the pedal from the floor.
    It's a '95 SR5 manual 5 speed and the clutch pedal has no pressure or return, it just stays on floorboard. Ideas anyone?
  12. Sep 2, 2015 at 4:48 PM
    #232
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
  13. Dec 26, 2015 at 12:05 AM
    #233
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I think there's a couple of dead links. "Grille Swap" is one. This is an awesome thread though. I can't wait to see what I can do.
  14. Dec 31, 2015 at 4:41 PM
    #234
    Jackz581
    Jackz581 pLaTe MaN
    Michael
    San Diego, CA
    01 Tacoma TRD
  15. Jan 21, 2016 at 9:43 AM
    #235
    boostd4
    boostd4 Member
    Fantastic resource, thanks!
  16. Aug 2, 2016 at 11:55 AM
    #236
    4wheeling1998
    4wheeling1998 Member
    Elbert
    1998 Tacoma
    tbd
    Appreciate the work put into this!
  17. Sep 2, 2016 at 11:28 AM
    #237
    DragonSlayer59
    DragonSlayer59 Member
    1995 Gray Tacoma Xtracab SR5 4x4
    What fuses or bulbs would I need replacing if once I turn on my lamps on for night driving and the ac unit configuration knobs do not turn on?
  18. Sep 2, 2016 at 1:14 PM
    #238
    DustStorm4x4
    U S A
    04 Jeep LJ
    Is it just the knobs or the whole AC lights and part of the speedometer lights? If it's isolated to just the knobs, then you have to replace the bulbs. There's a YouTube video showing on how to replace them. Just search it up and you should find it.
  19. Sep 7, 2016 at 12:29 PM
    #239
    DragonSlayer59
    Great thanks! Getting it fixed. Driving at night blindly pressing air controls instead of the radio
  20. Sep 10, 2016 at 1:39 PM
    #240
    DragonSlayer59
    So I fixed it. There's was a video on,one for it, thanks again. Took me 5 mins to do but an hour to try and find a auto shop what carried that tiny bulb lol
