1st Gen. "DIY" and "How To" Thread: Compiled list of helpful links
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, May 29, 2010.
  1. Nov 30, 2018 at 7:24 PM
    #281
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    That is pretty good. I paid ~$320 to have mine rebuilt locally with all new Spicer U-joints a back in May. Not much more tho get an entirely new assembly.
    Hey John, where's that post/thread you made about the diff vent/breather replacement? I can't seem to find it
  2. Nov 30, 2018 at 7:25 PM
    #282
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    thats great, I'm excited. I had some wibbles, thats what lead me to disassembling my ujoints only to find out they dont come out. now she'll be a steady beast.
  3. Nov 30, 2018 at 7:29 PM
    #283
    1997tacomav6
    Denver
    This one?
    Funny thing is I replaced the breather valve, then purchased the the parts for the real axle seal and bearing and guess what?
    Now the seal stopped leaking after replacing the breather valve, :)))
    https://www.tacomaworld.com/threads...ding-seals-and-bearings.577201/#post-19120234
    boostedka[QUOTED] likes this.
  4. Nov 30, 2018 at 7:38 PM
    #284
    boostedka
    James
    NM
    Thanks for the link! Crazy that cured your axle seal leak. I wonder how many other trucks would have benefited from the same thing? That's definitely a much easier fix!
    1997tacomav6[QUOTED] likes this.
  5. Nov 30, 2018 at 7:42 PM
    #285
    1997tacomav6
    Denver
    I think I caught it early, the pressure buildup must have been pushing the seal out and then coming back in after the pressure was relieved through the seal till I replaced the breather.
    Got luck, I have 250.00 worth of bearings, seals, gaskets and shoes I get to return to Toyota now, :))
  6. Nov 30, 2018 at 8:04 PM
    #286
    boostedka
    James
    NM
    So I just went to buy one of those diff vents and it had some coupon code come up for 25% off max $25 discount (PSAVE25) if you pay with a CC instead of PP. Pretty sweet.... So I added a set of headlight housings I had in my watched items and got 25% off those too!
  7. Dec 18, 2018 at 8:42 AM
    #287
    Nate3265
    Nate3265 Well-Known Member
    Nate
    2002 toyota tacoma
    Stock
    Thanks these are very helpful
  8. Jan 5, 2019 at 10:58 PM
    #288
    Robert61899
    Robert61899 Well-Known Member
    Robert
    Blacked out 2004 Toyota Tacoma Double Cab
    Brake pads was pretty useful and easy to understand:thumbsup:
  9. Jan 6, 2019 at 7:13 AM
    #289
    1997tacomav6
    Denver
    Started leaking again so got new bearings and seals done and brake pads
    Brice and boostedka like this.
  10. Mar 12, 2019 at 5:25 PM
    #290
    kokose7en
    kokose7en Well-Known Member
  11. Apr 20, 2019 at 12:37 AM
    #291
    prerunnerSD
    prerunnerSD Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    The links on this for the differential and transfer case gear oil change how to, is not for the 1st generation models its for the 2nd generation.
    Anyone know where I can find a good write up for the 1st generation differentials and transfer case gear oil change?
    Thanks
    Jonathan
    divesummit
  12. May 16, 2019 at 2:56 AM
    #292
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    This is a great thread:thumbsup:. Thanks to all of the contributors who are making my life easier:cheers::cheers:
  13. May 23, 2019 at 7:16 PM
    #293
    SunCityBob
    SunCityBob Member
    Bob
    Phoenix
    1999. 2.4 sr5
    Try the Haynes Manual?
  14. May 28, 2019 at 6:31 PM
    #294
    SATX_Tacos
    SATX_Tacos Well-Known Member
    San Antonio
    '02 Tacoma TRD Pre-Runner
    Anyone have a power window repair write up? Replacing the regulator and motor? I see that the link on the first page is broken
    Dalandser likes this.
  15. May 28, 2019 at 8:45 PM
    #295
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @BartMaster1234 or @mechanicjon will be able to guide your search I'm sure.
    SATX_Tacos[QUOTED] likes this.
  16. May 29, 2019 at 6:59 AM
    #296
    SATX_Tacos
    San Antonio
  17. May 29, 2019 at 11:40 AM
    #297
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    How have you determined it’s the motor and regulator that’s bad? Regulators rarely go bad. Motors do go bad commonly so that could be one thing.
    However I wouldn’t rule out the master switch either. Remove the door panel. Roll down the window until the bolts for the regulator are accessible from the hole in the door, unbolt the regulator, remove regulator and motor.
  18. May 29, 2019 at 12:05 PM
    #298
    SATX_Tacos
    San Antonio
    I dont know for sure, so I'll definitely do that first.
    I just assumed mainly due to the window going down perfectly fine, but when I try to roll it up it stops and I'll have to wait a few seconds then it'll go up a little more, I have to repeat this process about 5x before it finally closes. Also was thinking mainly due to the age of the truck itself that it might be due. I have an 02 Taco
  19. May 29, 2019 at 12:06 PM
    #299
    BartMaster1234
    Tyler
    Flux Capacitor
    That sounds like the motor to me. But take out the master switch and clean the contacts first.
  20. May 29, 2019 at 12:11 PM
    #300
    SATX_Tacos
    San Antonio
    Thanks for the advice!
