1st Gen Door Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by FF_Tacoma, Jul 9, 2019.
  1. Jul 9, 2019 at 7:31 AM
    FF_Tacoma
    FF_Tacoma [OP] New Member
    2001 Black Tacoma Double Cab Limited TRD PreRunner
    Hey there, so I just had a problem with my driver side door of my 2001 Tacoma. As of now it will unlock and open from the inside and will actually still lock. However from the outside the handle is completely loose without any tension in it. Anyone have any ideas as to what it could be? Any help would be greatly appreciated.
    GQ7227 likes this.
  2. Jul 9, 2019 at 7:43 AM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    There is a rod inside that the handle pulls to unlatch while pulled from the outside. Take the handle off & adjust where it grabs that little rod. It's become loose & not grabbing where it is supposed to.
    I didn't do this, 3wks later I broke my passenger door outside handle due to no tension on the inside of the door. New handle from the stealership: $130, adjusting the pull action: $free.
    Still haven't replaced it, but I wish I fixed it when I noticed it instead of ignoring it.
    GQ7227 likes this.
  3. Jul 9, 2019 at 2:29 PM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    If the adjustment described above works for you, then great. But if you do end up replacing the outside door handle, I strongly recommend the OEM part vice a parts store part.
    Trowbocop likes this.
  4. Jul 9, 2019 at 2:35 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    There are some really small clips on the end of the rod. Those are dealer only items I believe and really easy to break. I had some sticking problems a while back and I sprayed the linkage and the lock cylinders with Houdini lock lubricant. That stuff is the bees knee man. NO problems ever again after using that stuff.
    GQ7227 likes this.
  5. Jul 10, 2019 at 8:05 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    I second OEM handles. I have placed three sets of rockauto handles on my dad's 98. LOL
  6. Jul 10, 2019 at 8:47 AM
    Trowbocop
    Nashville, TN
    03 Tacoma SR5 4x4
    Good to know- I now plan on OEM based on everyone's feedback. Looked on ebay/Amazon, they're available for just above $100, saves ya 30 bucks from the dealer at least.
