1st Gen Double Cabs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Croth51, Apr 20, 2015.
  1. May 21, 2015 at 7:20 PM
    #141
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Oh my god that thing is fuckin sweet :drool:
  2. May 21, 2015 at 8:59 PM
    #142
    bullcrew
    bullcrew Well-Known Member
    travis
    oceanside
    03 quad cab sas
    Fine...do 80 down the freeway and 75 easily up the grades...gas mileage dropped off a little and it isn't as peppy as with 37s but no complaints...
    I will say if I wasn't deep into rocks all the time ID be running 37s period...best of everything and never got stuck or had to back down...the 40s make certain nasty obstacles a bit easier so I tent to veer towara making those nastier.
  3. May 23, 2015 at 7:14 AM
    #143
    Twitch.
    Twitch. Well-Known Member
    Well here she is, need to get my rear bumper side rails and a compressor.
    20150523_080416.jpg 20150523_080546.jpg 20150523_080433.jpg 20150523_080524.jpg
    SecureIT2021 and 2002Tacoma4x4 like this.
  4. May 23, 2015 at 2:15 PM
    #144
    Croth51
    Croth51 [OP] Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    how do you like those uca
  5. May 23, 2015 at 3:55 PM
    #145
    Twitch.
    a little wired at first then they break in, but I can't tell how much any one part effects anything because it went from stock to this.
    what would I looks for? in the difference of UCA's... I haven't taken up the trails yet I probably will tomorrow.
  6. May 23, 2015 at 3:59 PM
    #146
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    more travel smoother cycling. im stock and wondering if i should go mid or long travel up front
  7. May 23, 2015 at 4:00 PM
    #147
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    and whats that silver thing on the back xle for the brake valve
  8. May 23, 2015 at 4:08 PM
    #148
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Wow, I was thinking tires that heavy would slow it down a bunch. Good the know the 3.4 is a trooper and keeps on trucking! I may do a 3.4 swap on my 1979 Toyota Pickup 4WD one day so need to know this stuff because it's going to be my crawler.
  9. May 23, 2015 at 4:09 PM
    #149
    2004TacomaSR5
    Jon
    Montana
    No way my poor old gutless 22R is going to turn something like 40's without screaming for help.
  10. May 23, 2015 at 5:20 PM
    #150
    Twitch.
    holds the brake cable up off the axle, drives me nuts it is silver.
  11. May 23, 2015 at 8:55 PM
    #151
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    paint it lol
  12. May 24, 2015 at 4:48 AM
    #152
    Twitch.
    I have a rattle can waiting, It has been wet in this area. lol
  13. May 24, 2015 at 7:02 AM
    #153
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Finally got it all together
  14. May 24, 2015 at 7:25 AM
    #154
    bullcrew
    travis
    oceanside
    03 quad cab sas
    Yeah it turns em just fine...we are day 3 at hammers now and have beat the p! $$ out of it ran the nasty stuff tried back door ran a waterfall on claw hammer and almost flipped backwards...almost went backwards on resolution on a Friday night run...crushed rear passenger door in...had to remove glass and bend out all functions were jammed....broke my Fairless etc....lol was a good trip....did it No dual cases and had power to pull waterfalls etc...
  15. May 24, 2015 at 11:22 PM
    #155
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    image.jpg Here's my contribution to the DC :)
  16. May 25, 2015 at 2:18 PM
    #156
    justcuz
    justcuz Well-Known Member
    my wife's 2001 and my 2003
  17. May 25, 2015 at 6:53 PM
    #157
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Haha Tacoma love
  18. May 25, 2015 at 9:02 PM
    #158
    bullcrew
    travis
    oceanside
    03 quad cab sas
    I need the doors from a passenger side in the silver....front and rear have been crushed as well as front fender passenger side...if anyone has a line on so e let me know....I'll run my sides into the ground and swap when these are completely raisened
    DESTINATION HAMMERS:
    So we hit the hammers Friday night ran chocolate thunder and resolution....tried back door a couple times didn't want t to break before the weekend.
    Then We hit claw hammer and all credit lines as well as I did the wall on left then off to SOS and took a newbie on tachammer. Then a few extra credit unamed lines. Got it fast in whoops as well as airborne a few times.....truck on 40s performed flawless....
    We also ran a couple other hammer trails.....I wanted SOS and the wall on claw hammer as well as lineup and give backdoor a shot this time out...
    Damage:
    Destroyed rear passenger door (removed panel and had to bend back to bet glass out of way to bend rest out so doors and locks as well as glass worked)
    Dented n rock assault housing up front
    Dented rear housing in and hit ring gear no gear damage
    Added another dent to passenger door driver side
    Smashed my winch fairlead and broke a chunk off
    Broke rear tail light
    Smashed the hell out of gas tank skid
    And some more stuff.....
    Truck drove home 80 mph no issues....
    Other damage I. Group and they didn't follow me on the nastier stuff...
    Mike broke a Dana 60 ring gear
    Other mike slashed a sidewall
    Buddy sliced maxxis trepadors
    We were not easy on stuff and I didn't take it easy on the rock assault front axle and Toyota rear with 40s....I had plenty of wheel spin and hopping....yes anything can brake But we are headed back to run johnson valley again soon and I will go harder next time....I don't drive like Ricky bobby lol...I get after it but not stupid never have been....
    2002Tacoma4x4 likes this.
  19. May 26, 2015 at 4:03 AM
    #159
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Damn man love the carnage
  20. May 26, 2015 at 4:40 PM
    #160
    2004TacomaSR5
    Jon
    Montana
    May not have helped in this situation, but you need sliders dude.
