1st gen drive systems explained please
Discussion in '1st Gen. Tacomas (1995-2004)' started by AZoldtacoma, May 31, 2019.
  1. May 31, 2019 at 9:56 AM
    AZoldtacoma
    AZoldtacoma [OP] Member
    Paul
    it’s a rookie question, but can someone explain all of the drive systems for the 1st gens, specifically 01-04.
    I get it if you have a 2wd truck, you only have one hub with one tire engaged, some models come with a rear locker to engage both rear wheels that lock the hub.
    Was the rear side an option on the pre runners?
    How does the 4wd work? Is it one front and one rear engaged? And then you have 4wd models with lockers, some front and some rear.
    Basic stuff but many manufacturers have different drive systems, would like to know, thank you
  2. May 31, 2019 at 10:11 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You got it right. I would only add that there were no 1st gen that came from the factory with front lockers.
    Speedytech7 likes this.
  3. May 31, 2019 at 10:17 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Also. No double cab 1st gen, 4 cylinder (3rz) prerunners came with rear lockers.(2001-2004).
  4. May 31, 2019 at 12:27 PM
    AZoldtacoma
    Paul
    Ok so it’s only the v6 double cabs that come with a locker.
  5. May 31, 2019 at 11:26 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Mines just an extra cab & has the locker.
  6. May 31, 2019 at 11:57 PM
    eon_blue
    Azusa, CA
    1995.5 - 2004 Tacomas came in 2wd 5 lug configurations and 2wd and 4wd 6 lug configurations.
    The 2wd 6 lug variations were called Prerunners and built on the same frame as the 4wd 6 lug Tacomas. Which is why they look identical to the eye unless you look underneath (because the 4x4s will obviously have a front drivertrain where the 2wd Prerunners wont).
    Prerunners came with an available rear differential locker on the TRD models, the 4x4s came with one as well on the TRD models. No 4x4 Tacoma has ever been offered with a front differential locker.
    That's it in a nutshell.
