1st gen eibach n billstein 5100s
Discussion in '1st Gen. Tacomas (1995-2004)' started by lunch box, Oct 4, 2014.
  1. Oct 4, 2014 at 7:42 PM
    lunch box
    lunch box [OP] diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    so I finished my install of billstein 5100s all around and installed eibach coils rated at I think 600 lbs...little nervous it may cause a ball joint or something to break..should I be nervous anyone had a bad experience with this?I run a 1st gen 2000.
  2. Oct 4, 2014 at 7:49 PM
    lunch box
    2000 trd tacoma
    im nervous about my upper control arm ball joint looks like its at a extreme angle...and dont want to spend a g stack on upper control arms..
  3. Oct 4, 2014 at 7:52 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Any pictures?? Did you set the billies at 0?
  4. Oct 4, 2014 at 7:54 PM
    Combatman
    Combatman Well-Known Member
    Sioux Falls sd
    1996 Tacoma 4x4 3.4 Manual
    31" Wrangler tires
    I just did the same install, and I have the same concerns. It seems like I got more than 3", how much lift did you get?
  5. Oct 4, 2014 at 7:55 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    It will put u up over 3" at first but they should settle to 3"
  6. Oct 4, 2014 at 7:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    its well known that they give about 3.5''.
    if you don't have any front weight you shouldn't have got the coils to begin with as they are too high a rate.
    they are made to have a heavy bumper with them at least. Skids and a winch help too.
  7. Oct 4, 2014 at 8:00 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    This guy knows whats up
  8. Oct 4, 2014 at 8:00 PM
    lunch box
    2000 trd tacoma
    I did the diff drop and the eibach and billstiens I did not do any measurements yet.and yeah I set them to 0 those springs made my spring compressor bend and strip threads was a bit sketchy but its done and is sick...just nervous about breaking a ball joint..just wondering if anything has broke due to this lift?
  9. Oct 4, 2014 at 8:03 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No your ball joints will be fine.
    If you had done some searching you would have found all this to be known info. Diff drop doesn't hardly help.
    If you don't get some weight up there you'll eat through your cv boots soon
  10. Oct 4, 2014 at 8:07 PM
    lunch box
    2000 trd tacoma
    I know they say diff drop does not help but for like 20 bucks and a hlf hr of labor it cant hurt.also Ive been waiting on my shrockworks bumper for like 2 months so Im preparing for that .............................................................but waiting....waiting...............................and more waiting....
  11. Oct 4, 2014 at 8:08 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha also should have researched shock works. You might not see that bumper for 3-16 months...most likely the later.
  12. Oct 4, 2014 at 8:15 PM
    lunch box
    2000 trd tacoma
    I know about the wait time and ive done the research I know...just after the install got a little nervous thought id ask...is that your truck in the pic?
  13. Oct 4, 2014 at 8:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes that's mine. If you click it it'll go to my build.
    Ah well...hopefully you'll get it.
    You'll be fine. Just be a bit stiff and ruin your cv boots
  14. Oct 4, 2014 at 8:21 PM
    lunch box
    2000 trd tacoma
    so you think I should have done something different?
  15. Oct 4, 2014 at 8:22 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'd have waited.
    Or gotten a 881 OME coil for now till the bumper showed.
  16. Oct 4, 2014 at 8:29 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    If u still have the stock coils you could take out the eibachs and just run the billies with the stock coils till you get some weight up front.
  17. Oct 4, 2014 at 8:30 PM
    lunch box
    2000 trd tacoma
    huh so ill be replacing cv boots till then? ouch...shrockworks wait time just scood me I was trying to prepare a head of time for the extra weight...hows the boot slide mod they talk about on here ..ive never done it?
  18. Oct 4, 2014 at 8:32 PM
    lunch box
    2000 trd tacoma
    I dont want to re do the job I just did ...really put the old coils back on...aaaahhhhhuuuuggghhh....dont tell me that,,,I love the way it is now and cant go back
    nnnnnooooooo....cant do that...
  19. Oct 4, 2014 at 8:33 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Haha cv boots aren't that expensive....
  20. Oct 4, 2014 at 8:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Boot slide mod is ok. Doesn't always work well though.
