1st gen elocker diff into 2nd gen elocker axle housing?
Discussion in 'Technical Chat' started by TireFire, Apr 18, 2017.
  1. Apr 18, 2017 at 10:36 AM
    TireFire
    TireFire [OP] Superunknown Member
    Olympic Peninsula
    Morning y'all! I'm hoping that someone in here has knowledge to confirm or correct my train of thought. I have a complete and totally stock axle from a 2012 TRD off-road that I'm trying to sell. My wife's cousin has a 2010 4x4 4banger and he wants to buy it from me but I initially told him it won't work because he has 4.10 gears in the front and for the cost to buy my axle and have it regeared he might as well get an ARB locker... now I got to thinking, what if he just pulls the third out of my axle, sells it and finds an elocker third with 4.10 gears from a first generation Tacoma? I believe both have 30 spline axle shafts and the mounting flanges are the same... sooooo... it SHOULD work. Am I missing something?
    Thoughts?
    Thanks!
  2. Apr 18, 2017 at 2:34 PM
    TireFire
    Olympic Peninsula
    Is the flange that connects to the drive shaft the same?
  3. Apr 18, 2017 at 2:51 PM
    TireFire
    Olympic Peninsula
    Looks like I gotta go to Ttora for answers....
  4. Apr 18, 2017 at 2:54 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    They are not interchangeable from 1st to 2nd gen
  5. Apr 18, 2017 at 2:56 PM
    TireFire
    Olympic Peninsula
    Why not?
    Brie likes this.
  6. Apr 18, 2017 at 2:59 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Because they are different. The 1st gen elocker uses an 8" diff and 2nd gen uses the 8.4"
  7. Apr 18, 2017 at 3:00 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I think he is asking if a 1st gen e locker third will fit into a 2nd gen e locker housing?? Right..?
  8. Apr 18, 2017 at 3:02 PM
    TireFire
    Olympic Peninsula
    Thanks for chiming in but you ar missing the point completely
  9. Apr 18, 2017 at 3:03 PM
    TireFire
    Olympic Peninsula
    Yessir! I think it should. Only thing I'm not sure about it the yoke flange that goes on the axle shaft...
  10. Apr 18, 2017 at 3:14 PM
    Cr250jumper
    The moon
    50 shades of tan©
    That is what I mean, axles have the same spline, flange on the pinion is the same for the driveshaft, but it looks like you would have to modify the housing, it would not be a bolt in fit. I have no idea what you mean with the flange on the axle shaft. I have a 1st gen elocker if you want to try it :)
  11. Apr 18, 2017 at 3:18 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    They're identical. I have a 2nd gen 3rd in my truck.
    Bandido and TireFire[OP] like this.
  12. Apr 18, 2017 at 3:23 PM
    TireFire
    Olympic Peninsula
    I misspoke. I meant the drive shaft flange. But you are still missing the point. Not trying to fit the elocker third into the so-called 8.4" housing. Read OP again!
  13. Apr 18, 2017 at 3:24 PM
    TireFire
    Olympic Peninsula
    Awesome!! No modifications required at all? What about the drive shaft yoke?
  14. Apr 18, 2017 at 3:29 PM
    Squeaky Penguin
    Brett
    3rd member is the same, was just questioning myself about the pinion flange however.
    When I regeared my '01, I had to buy a new flange being the pinion had 29 splines and stock was like 27. Don't know if that means the bolt spacing is different.
  15. Apr 18, 2017 at 3:36 PM
    TireFire
    Olympic Peninsula
  16. Apr 18, 2017 at 3:43 PM
    Squeaky Penguin
    Brett
  17. Apr 18, 2017 at 3:47 PM
    TireFire
    Olympic Peninsula
    Right, well looks like project is a go! I got a local guy offering his 4.10 3rd from a 2003. Guess I'll count splines and see if I need the different yoke at all. I will also give East Coast Gear Supply a call and see what they think
  18. Apr 18, 2017 at 3:56 PM
    TireFire
    Olympic Peninsula
    Why would I need this if the 4.10 elocker diff I'm buying already has 29 splines on the pinion?
    My concern is mating the pinion from the first gen diff to the 2nd gen drive shaft.
    Does anybody know the spline count on the 2005+ non elocker pinion gear? And is it different between V6 (3.73 gears) and 4banger (4.10 gears)?
  19. Apr 18, 2017 at 4:10 PM
    Squeaky Penguin
    Brett
    I still don't know if the driveshaft bolt patterns are the same. All I was saying is you could only use that flange if you got a 1st gen diff with a 29 spline pinion.
  20. Apr 18, 2017 at 4:16 PM
    TireFire
    Olympic Peninsula
    Gotcha. But if you did the opposite of what I'm looking into (2nd gen diff into 1st gen axle housing) and it bolted up to your drive shaft then the opposite would be true for me, right?
