1st Gen Extended Cab Pics
Discussion in '1st Gen. Tacomas (1995-2004)' started by rpoint16, May 22, 2018.
  1. Aug 2, 2018 at 7:22 PM
    #81
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nice! Welcome :)
    baachor[QUOTED] likes this.
  2. Aug 4, 2018 at 11:14 PM
    #82
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
  3. Aug 4, 2018 at 11:27 PM
    #83
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    What color is that?
  4. Aug 4, 2018 at 11:37 PM
    #84
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    No idea,I just walked out of 711 and I saw the MySpace angles in action. So I took a photo.
    Sperrunner[QUOTED] likes this.
  5. Aug 4, 2018 at 11:41 PM
    #85
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its like a metallic purple, looks pretty cool
  6. Aug 4, 2018 at 11:55 PM
    #86
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    Sunfire red pearl during a sunset with multiple forest fires burning
  7. Aug 4, 2018 at 11:56 PM
    #87
    Speedytech7
    Sunset Brushfire Red Pearl
  8. Aug 4, 2018 at 11:58 PM
    #88
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Oh I didn’t even realize you were local to me lol. Yeah these fires are bad...
  9. Aug 5, 2018 at 6:34 AM
    #89
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    You're right, it is a shitty choice: buy a new one and watch it rust and depreciate; or drive and old one and deal with the rust, like I am.
    My 95 lived in Iowa, Wisc, and now Indiana. My Dad's 95 was an Indianapolis lifer. So, any work I do on the underbody/chassis of either truck, I already know there is a better than 50-50 chance that every bolt/nut will be rusted solid and anything <14mm will probably twist off. I have had every one of the following break off at least once: bleeder screws; fuel/brake line fittings, O2 sensor nuts; exhaust bolts; fenderliner/mudflap screws; bed bolts; fuel pump screws and tank front bracket; heat shield bolts; ... Most of those, more than once. I went to pull my passenger seat last week and both the outside bolts twisted off.
    PB Blaster, forget about it. It helps after you have the bolt/nut moving, but rarely before. Impact on low torque and oxy/acetyl heat helps, but still lose most of the time. I even used the "candle wax trick" and had a little success on bleeders.
    Rust sucks, but we're stuck with it here. Get it, stuck with it... We just learn to assume that will be part of the repair process.
  10. Aug 5, 2018 at 7:05 AM
    #90
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Buy from ca, import and fluid film / krown :spy:
    Fuergrissa likes this.
  11. Aug 5, 2018 at 4:21 PM
    #91
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
  12. Aug 5, 2018 at 4:58 PM
    #92
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Figure Ill play too. A shot right after I finished my rear suspension set up n me winching a second gen back on the trail after we told him to stay on the rocks n not the soft dirt below.639157D2-0B41-401B-A425-F891808CE112.jpg
    QMEDJoe, Sperrunner and AtlasV like this.
  13. Aug 5, 2018 at 8:57 PM
    #93
    QMEDJoe
    Joe
    How do you like them Ray 10’s?
    Mine were delivered a couple of days ago in Matte grey but I’m going to order new rear custom springs from rather Deaver or Alcan and the rear swing out tire carrier from CBI off-road. I’m probably going to put new ko2’s on them prior to install.
    :spending:
    Prayn4surf[QUOTED] likes this.
  14. Aug 5, 2018 at 9:11 PM
    #94
    Prayn4surf
    Socal
    Theyre method nv’s got em quite a while ago. But they work pretty well. Only downside is the center cap, ripped one off so far n shaved another one down a bit. My friend loves his ray10s im sure you will as well. I play in the rocks too much to warrant new wheels. I really like the bronze sr8s though.
    QMEDJoe[QUOTED] likes this.
  15. Aug 5, 2018 at 10:07 PM
    #95
    QMEDJoe
    Joe
    Yep, I’ve wanted them for quite a while now. I tried a few times and missed out. They’ll definitely get their share of scars. :thumbsup:
  16. Aug 5, 2018 at 10:57 PM
    #96
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
  17. Aug 6, 2018 at 2:10 PM
    #97
    VBdiver58
    VBdiver58 Well-Known Member
    Virginia
    1999 Tacoma xtra cab 4x4 2.7L
    16" Toyota rims
    my 1999 with late model rims and new rubber . got to figure out some shelter for her.
    neighbors pine tree brutalizes it.
    Tacomaman63, Wsidr1, TortyB and 2 others like this.
  18. Aug 6, 2018 at 5:01 PM
    #98
    Bootselectric
    Bootselectric Well-Known Member
    Stirling
    2004 PreRunner (RIP) 2013 TRD Sport (DCSB-BRM)
  19. Aug 7, 2018 at 1:03 AM
    #99
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    What kind of truck camper do you have mounted on in your truck bed?
  20. Aug 7, 2018 at 2:08 AM
    #100
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
