1st gen Fog Light Wiring
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoman101, Nov 17, 2009.
  1. Nov 17, 2009 at 3:24 PM
    tacoman101
    tacoman101 [OP] Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I'm to cheap to buy myself a light bar, so im going to mount lights on the front bumper. I just have some questions about this type of mounting and would like some pics of your mount on the front bumper, and also how do you wire it in order to make it so you have a switch inside the truck, thanks ahead of time
  2. Nov 17, 2009 at 5:11 PM
    tacoman101
    scott
    vermont
    bump...anyone?
  3. Nov 17, 2009 at 5:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I made some "L" brackets and mounted them to the frame. I made them long enough to where the lights would be flush with the bumper. I chose this method so as to keep the lights from bouncing around when I was off roading. Only pic I have is this one.
  4. Nov 17, 2009 at 5:47 PM
    tacoman101
    scott
    vermont
    I was actaully thinking of the lights to the bumper, kinda like this:
    I just don't really know how its mounted, or wired
  5. Nov 17, 2009 at 5:53 PM
    tacoman101
    scott
    vermont
    haha how did you mount/wire them
    nice pic by the way
  6. Nov 30, 2009 at 2:51 PM
    jrcoyote21
    jrcoyote21 Member
    AZ
    01 Tacoma Limited 4x4
    i just bought a tacoma with lights mounted to the bumper. is this what you are looking for?
  7. Nov 30, 2009 at 3:04 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I mounted mine in the bumper similar to Chris. As far as the wiring goes, they came with a harness and relay. The relays are on the firewall with the switch wires running through the firewall under the dash. I got two fog light switches from a similar year Camry and they fit right in the blanks behind the shifter. Looks pretty factory.
  8. Nov 30, 2009 at 3:09 PM
    JDMcQ
    My switches:
  9. Nov 30, 2009 at 7:26 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    i need some of those "L" shape brackets u made! do u remember the measurements & all?
  10. Nov 30, 2009 at 9:59 PM
    Will Prerunner
    Will Prerunner Well-Known Member
    Tempe Az
    01 TRD Prerunner Doublecab
    Trail-Gear rock sliders, OME Lift, kobalt tool box, herculined fender flares, CrossFab light bar, Deck plate Mod, Differential Breather Extension, 32"goodyear duratracs Pioneer 3 way speakers, alpine head unit, Boss Bass 600 sub, custom az pinstriping
    I have the fog lights below like jr coyote, and have been wanting to add lights to the bumber but have been nervous to drill into fearing i'll screw it up.
    I would definitely suggest using a relay when you wire them up, the easiest way to wire them is to just wire them up right to the battery. This is how mine are wired, but it is better to wire them into the headlights or some type of switch that turns off when the car turns off so they don't drain your battery if you leave them on.
