1st Gen Frame Recall
Discussion in 'Canada' started by Ric4709, Nov 26, 2016.
  1. Nov 26, 2016 at 10:46 AM
    Ric4709
    Ric4709 [OP] Member
    Ric
    2002 4x4 Double Cab
    I bought my 02 double cab last summer. I didn't know much about these trucks at the time. Just always loved the look of them. Anyway, the guy told me that he had Toyota tell him the frame was ok and didn't need a recall. But had it reinforced... I'm pretty much Screwed if anything happens right? Or should I be contacting Toyota to try and get the "reinforced" one replaced? It has started to rust some. From what I understand it has been sprayed every year since it was reinforced.
  2. Dec 28, 2016 at 12:59 PM
    MoonKnight
    MoonKnight Well-Known Member
    chris
    Oromocto New Brunswick
    2018 silver Tacoma TRD or
    i need a frame replaced i called my local dealership about it last year and they laughed at me they won't do anything about it
  3. Dec 28, 2016 at 1:01 PM
    eon_blue
    Azusa, CA
    First gens only qualify for the frame replacement if they were inspected and coated by Toyota prior to the 2011 deadline. If you made the deadline, then you have 15 years from the build date of your vehicle to get the frame replaced IF Toyota inspects it again and deems it unsafe to drive.
    So right now, only 2002-2004 first gens would qualify for the replacement program, assuming they had been inspected/coated prior to 2011
  4. Dec 28, 2016 at 1:03 PM
    eon_blue
    Azusa, CA
    Oh and you have to live in one of the specific states that Toyota named in the program, pretty much any state with harsh winters that uses salt on the roads during winter I think.
  5. Dec 28, 2016 at 1:08 PM
    MoonKnight
    chris
    oh i see , then probably not since i bought mine from a auction in nova scotia last year they said frame was good looked good
    then cab mounts are going shock broke off frame broke just over the top of the passenger side
    when i took it into to place down here to get a aliment done they asked have you seen this frame its really bad
    since then bought a 2007 that needs a engine replace
  6. Dec 28, 2016 at 1:09 PM
    eon_blue
    Azusa, CA
    actually, sorry guys...I didn't realize this was in the Canada section. What I posted before applies to 1st gen frame replacement program for the US, I'm not sure what the program for Canada was like. It may have been the same, may not have been.
  7. Dec 28, 2016 at 1:13 PM
    MoonKnight
    chris
    no worries ,when i found out mine needed a frame like i said i called toyota about it and they told me they weren't doing 1st gens anymore (under the recall anyway) i could still probably have them do it for me but id probably have to pay the amount of a brand new truck
  8. Dec 28, 2016 at 1:36 PM
    eon_blue
    Azusa, CA
    Yeah I remember a member on here posted the invoice for his frame replacement through the Toyota recall program, he owed nothing of course but the invoice stated that the frame job was something like $12,000
  9. Dec 28, 2016 at 1:36 PM
    eon_blue
    Azusa, CA
    Best bet would be to either find a donor truck with a clean frame to do your own swap with, or try to repair/patch your current frame depending on how bad it is.
  10. Dec 28, 2016 at 1:47 PM
    MoonKnight
    chris
    I already have a back up i recently bought a 2007 V6 I've seen this one frame looks brand new only thing is i bought it knowing it needs a engine replacement
    or re-build , my father has the truck right now and is going to do the engine replacement for me since he has the garage to do it and all the tools and equipment needed
  11. Jan 1, 2017 at 2:21 AM
    toytruck2003
    toytruck2003 Member
    2003 Green Tacoma Base ext cab 4x4 5 sp
    One dealer said it wasn't covered , but it had been inspected in 2009 and undercoated at the time by Toyota and the warranty had been extended to 15 yrs after mfg date.
    So I went to another dealer and just got my 2003 back from the dealer Kentville Toyota with a frame replacement , had been waiting for the frame since June 2016.
    Optioned to put on power steering lines , upper ball joint , proportioning valve linkage that had been removed , cost $1500 ( parts ,labour, shop supplies,tax), which wasn't in the list of warranty parts.
    But frame , new springs , lower control arms etc no charge for ~ $6000 worth of parts , and ~$6000 worth of labour.
    PS lines from Toyota was ~$1000 from Toyota , got from napa for $400 , but couldn't get linkage from napa , which they charged $580 from Toyota , labour $230 , various other parts not covered.
    If yours is approved , get a list of parts that are needed which aren't warranty , before it goes in for work , and try to source yourself , or the dealer will likely say they can't wait and they need to get from Toyota , who have inflated prices.
  12. Jan 1, 2017 at 2:25 AM
    toytruck2003
    toytruck2003 Member
    If a frame is welded , I've heard that it has to be done by a certified welder , body shop , for it will pass safety check. Not sure , but your work could be for nothing.
