1st gen gear oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by crymfighter, May 6, 2020.
  1. May 6, 2020 at 6:48 AM
    crymfighter
    crymfighter [OP] Active Member
    Lance
    2000 Silver Tacoma 4x4 SR5 TRD
    stock
    I know there is a lot of stuff already typed up on this subject (i've read most) but I still have questions. I've recently started doing some upgrades to my truck (i'll post pics soon) and i'm going through everything. I've read a lot over the past few weeks. And scoured the internet forums and sites. My question is about gear oil. My Tacoma is a 2000 4x4. Book says SAE 75w90 Hypoid oil. I went with Mobil 1 Synthetic 75w90 because it got great reviews and a lot of people are on the synthetic band wagon. Wasn't cheap but couldn't afford Redline either. When I went to change out the rear diff the oil was green (actually looked like green antifreeze). I thought, hmmmm, ok. Well changed front, rear, and transfer case out. Transfer case oil wasn't green though. Went to drive it and started hearing a hum coming from rear end. Only drove about 4 miles so not too worried. But from what i'm learning, 1st gens apparently don't like synthetic oils. At least mine doesn't. So now i'm going to recycle expensive oil and buy more new crush washers :(
    Does anyone know what the green oil might be? And is Valvoline about the best conventional gear oil to go back with? It hasn't been submerged in water btw. Seen lots of people say water mixed in is green. Had no water in fluid, not foamy.
  2. May 6, 2020 at 7:26 AM
    Zimm!
    Zimm! Well-Known Member
    1999 Extra-Cab TRD 4x4
    That's weird, sorry I'm no help. good luck!
  3. May 6, 2020 at 7:37 AM
    butters_
    butters_ Well-Known Member
    Mammoth Lakes, Ca
    2000 4x4 trd manual
    Not enough
    Possibly cycle more through. I have the same year truck and switched to Mobil 1 syn with no issues.
  4. May 6, 2020 at 7:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'd drive it more first.
    2nd, you shouldn't need new crush washers if you do change it.
  5. May 6, 2020 at 7:52 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Mobile 1 75W90 is perfect.
    Supertech is also dandy
  6. May 6, 2020 at 7:57 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    The green oil was most likely lucas gear oil in the viscosity recommended for the truck. Its what I use and is green.
  7. May 6, 2020 at 8:14 AM
    crymfighter
    Lance
    stock
    Thanks for the replies guys!
  8. May 6, 2020 at 9:09 AM
    Wulf
    rock raisin
    Lucas is what is recommended by East Coast Gear supply so I run it in the diffs. I can't say I'm a fan -- I've had a couple bottles where the additives are all settled in the bottom
    T Case gets Mobile 1 or Supertech depending on what's on hand
  9. May 6, 2020 at 10:26 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've seen some heavier weight oils that look green. Supertech 85-140 is green looking if I recall. You can get big jugs of Supertech gear oil for cheap. I use supertech in everything except my 5 speed tranny, which now gets Redline.
    Wulf likes this.
  10. May 6, 2020 at 10:28 AM
    Wulf
    rock raisin
    I've had STP/Coastal gear oils that are darker with green tint instead of honey colored as well
    ThunderOne[QUOTED] likes this.
  11. May 6, 2020 at 11:40 AM
    crymfighter
    Lance
    stock
    I read through East Coast's data on gear oils that @Wulf pointed out. The 85w140 they recommend makes sense.
  12. May 6, 2020 at 12:25 PM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    I agree that more time with it (barring hearing some catastrophic sounds) is a good idea, and if further concerned do another change to cycle more new oil into the diff. I used redline 75-90 in front/rear/xcase and all is well.
