1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Sep 2, 2024 at 7:43 PM
    #2121
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    He has digi throttle, Haltech not controlling... Same as @austinmtb
  2. Sep 2, 2024 at 7:48 PM
    #2122
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Yeah That... I'll turn it back off
  3. Sep 2, 2024 at 8:02 PM
    #2123
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Ahh
  4. Sep 2, 2024 at 8:09 PM
    #2124
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    Crazy idea.. make a flange, weld to intake plenum, then use Iacv of your choice to fine tune Dvw idle imperfections in piggy mode. 5vz or 1jz valve, or something else possibly.
  5. Sep 2, 2024 at 8:11 PM
    #2125
    Speedytech7
    I mean you could do that but it would always be messing around on its own because the other iac is always adjusting independently. It'd be like impossible to get a base duty cycle
  6. Sep 2, 2024 at 8:33 PM
    #2126
    Jon64l
    Jon
    I'm saying just use it when idle drops below X value. Like a stall saver.
  7. Sep 2, 2024 at 8:44 PM
    #2127
    Speedytech7
    Oh okay, yeah that might work. You can get a two-wire or a three wire BAC valve out of just about any old '90s BMW
    unstpible likes this.
  8. Sep 2, 2024 at 11:25 PM
    #2128
    unstpible
    Derek
    Cedar City, Utah
    I'd also like to note that I'm still getting a P1301 code as well.
    1997tacomav6[QUOTED] likes this.
  9. Sep 3, 2024 at 8:13 AM
    #2129
    Speedytech7
    That's likely the cause of longer starts, usually a start just takes a key bump to get going.
    Anywho, I'm on here if someone needs something but I'm working on a lot of local builds at the moment. Working on a product for the mechanical speedometer folks (pickups and 4runners prior to 1995 and tacomas prior to 1998). Some good old fashioned hardware debounce since I cannot define a filter in the Haltech that can deal with bouncing reed switches.
    unstpible[QUOTED], Jon64l and jubei like this.
  10. Sep 3, 2024 at 8:23 AM
    #2130
    treyus30
    Trey
    Mesa / AJ, AZ
    I've not seen the tables for e-pedal control. You must have several things that tell it what to do when it's at 0%?
    Hate to say it, but if you're not going to put in the time to learn how it all works yourself I agree you should pay someone before you get stuck somewhere.
    unstpible[QUOTED] likes this.
  11. Sep 3, 2024 at 8:27 AM
    #2131
    treyus30
    Trey
    Mesa / AJ, AZ
    On another note, I decreased the decel cutoff to 1100RPM a week ago to no ill effects. Seemed to have picked up an mpg even. Might even try 1050 or 1000 since it likes to hover there at speeds slightly above my 25mph cutout.
    The torque converter is such a hog too. My idle trims 'in gear' have skyrocketed. Definitely a good idea to put that axis in if you can on an automatic.
    Also reduced my base idle RPM from 750 to 650 and I think I like it better.
  12. Sep 3, 2024 at 8:34 AM
    #2132
    Speedytech7
    There's no tables for e-pedal control on his, it isn't being controlled by the Haltech. His Haltech can only see the TPS actual value to do it's enrich and whatever else is assigned to TPS demand. But yeah I'd agree it needs a full tune now. It's probably pretty close in a lot of places since I gave him a fairly well defined 5VZ map but it is going to be missing things related to idle and steady state... probably could use a lot of zero demand maps defined (since I normally avoid using those I didn't have any configs on hand to start him off with) to help with the no idle control and maybe turn on ign only idle control for small corrections.
  13. Sep 3, 2024 at 8:38 AM
    #2133
    Speedytech7
    Which decel value have you been adjusting... I've been wanting to refine mine a good bit for a while
  14. Sep 3, 2024 at 8:39 AM
    #2134
    treyus30
    Trey
    Mesa / AJ, AZ
    I see. In that case I'm shocked he's even gotten this far. So he TPS/RPM ignition tables?
  15. Sep 3, 2024 at 8:40 AM
    #2135
    Speedytech7
    What? No it's still pressure over RPM like normal haha, it just essentially believes he has a cable throttle with no IAC. Which isn't uncommon in the racing world.
  16. Sep 3, 2024 at 8:42 AM
    #2136
    treyus30
    Trey
    Mesa / AJ, AZ
    I can get you a screenshot maybe later, but I basically dropped the "Decel Min RPM" -350RPM/sec at operating temp cells to 1100 and kept the -800RPM/sec a little higher. And tweaked the cut delay time table a smidge (which I've felt kick in so might be a tad aggressive now)
  17. Sep 3, 2024 at 8:44 AM
    #2137
    treyus30
    Trey
    Mesa / AJ, AZ
    Ok so no real correction tables in place for TPS or zero demand then, just the base ignition table?
  18. Sep 3, 2024 at 8:44 AM
    #2138
    Speedytech7
    Ah okay, I wondered if those derivative axis numbers were in need of an adjustment to really dial mine in, have to imagine inertia of the engine crank/flywheel/clutch/drivetrain (when in gear) play a role in whether those are right for the application or not
  19. Sep 3, 2024 at 8:47 AM
    #2139
    Speedytech7
    Yeah he doesn't have any zero demand tables configured. Not sure what I'd use TPS for in a correction, but he's using TPS for decel cut and I'd like to see what the TPS does at idle to see if I can use it for a zero demand IGN and FUEL table to help make a persistent idle. Might vary too much with the stock ECU moving it and he's at higher elevation so swings would be larger too, might have to use MAP value to determine zero demand steady state.
    treyus30[QUOTED] likes this.
  20. Sep 3, 2024 at 8:47 AM
    #2140
    treyus30
    Trey
    Mesa / AJ, AZ
    Ya I would imagine a manual might be a tad more complicated to set up properly too. The auto LOVES the 1000-1500 RPM range. The only time I have fast -RPM/sec is when I'm in high RPMs, and by the time the cut delay has been reached, it's slowed down significantly anyway, so the -800RPM/sec row is probably rarely used at all...but still useful for interpolation ig
