1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Aug 17, 2022 at 2:40 PM
    #201
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    That's actually quite impressive that you can command all that from something that wasn't necessarily designed to do it.
    1997tacomav6 likes this.
  2. Aug 17, 2022 at 2:41 PM
    #202
    1997tacomav6
    Denver
    If I remember I think Gabe can, but depending on the year, maybe dive by wire was part of the equation?
  3. Aug 17, 2022 at 2:54 PM
    #203
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This sounds promising. I'll sign up for that. Accuracy of speed in 4lo seems like a low priority.
  4. Aug 17, 2022 at 3:20 PM
    #204
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Anyone with a Haltech 2000 or 2500 can, its like any other feature, it's all there for you to play with but I/O is the hot commodity and controlling the trans eats a bit of it up. Especially if you have drive by wire since your I/O would be heavily eaten into with the dual throttle sensors and the throttle motor plus the trans line pressure solenoid too. Much easier if it isn't a DBW model. Even a Haltech 750 can control a trans I think but you'd have to have a PD16 or a microsquirt (attached by CAN) to have enough I/O. Looks rather straight forward otherwise and enables some nice features to help the auto not get beaten up by the boosted 5VZ
    1997tacomav6[QUOTED] likes this.
  5. Aug 17, 2022 at 3:28 PM
    #205
    1997tacomav6
    Denver
    Have you got your haltech up and running?
    I noticed my scan gauge shows 13.2 volts with haltech,
    But with the stock ECU it shows 14.2 volts.
    Is the haltech able to run below 13 volts without causing issues?
    Still trying to figure out my trigger issues
  6. Aug 17, 2022 at 3:40 PM
    #206
    treyus30
    Trey
    Mesa / AJ, AZ
    https://nextlevelmotorsport.com.au/...agement/products/a340-gear-position-convertor
    ^ The HT article links to that to save some ports, but that's a ridiculous price for what it is.
  7. Aug 17, 2022 at 3:41 PM
    #207
    Speedytech7
  8. Aug 17, 2022 at 3:42 PM
    #208
    treyus30
    Trey
    Mesa / AJ, AZ
    Yep, pretty much. You could go full digital too for like an extra 5 bucks
  9. Aug 17, 2022 at 4:00 PM
    #209
    Speedytech7
    The haltech just doesn't like being below 10v it might not actually start below 11. But 13 is fine, that's technically still above a full battery which is 12.6v
    I'm installing mine this Friday so I can start my NA tune
    jubei and 1997tacomav6[QUOTED] like this.
  10. Aug 17, 2022 at 4:28 PM
    #210
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I've just been sitting on all of the parts since they arrived. Currently trying to wrap up my engineering degree so I've been pretty busy with that and haven't had a whole lot of time or money for the truck lately. I think I'll get around to installing everything this fall so I'll be sure to read about everyone's issues that they're running into. I'll be doing the remote tuning with Gabe so hopefully he'll have fixes for most or all of the issues by then.
    Digiratus[QUOTED] likes this.
  11. Aug 17, 2022 at 5:00 PM
    #211
    1997tacomav6
    Denver
    Let me know if you have a voltage drop from before and after with stock ECU and then haltech
  12. Aug 17, 2022 at 5:03 PM
    #212
    Speedytech7
    @DrabT100 How is it all coming lately, been quiet
  13. Aug 18, 2022 at 3:04 PM
    #213
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    I drove the truck around quite a bit last Saturday (cruise night where I live) which gave me a chance to do some road tuning. I am still dealing with the idle and it does stall randomly when starting hot or just coming to a stop after pushing the clutch. The low idle after a hot soak was there before the haltech so my IAC may be on its last legs. Other than that it is great, i havent gone into boost control much yet though. I also have a water injection setup I will be installing and letting the haltech handle as well just for a little safeguard. I have been away all week so lots still to do when I get back.
  14. Aug 20, 2022 at 10:36 AM
    #214
    Digiratus
    Roaming the PNW
    The RedHead
    When you see this discrepancy, have you taken a reading at the battery with a multimeter?
    I have seen a voltage drop of about ~.5VDC with the Haltech. This difference can be seen between the reading in the Haltech software and my scangauge which is connected to the OBDII port which, on my truck, is still managed by the OEM ECU.
  15. Aug 20, 2022 at 11:01 AM
    #215
    Speedytech7
    Mine is reporting within .3v of what's measured at the battery.
  16. Aug 20, 2022 at 11:35 AM
    #216
    Speedytech7
    Interesting point of note, yesterday when getting my truck working on the haltech, every time I would have crank trigger issues they'd arise on the 33rd tooth of the crank trigger wheel. Not sure what that's about. But after going to Nexus and looking in the oscope, I got it as far as 4100k. Still needs more work and the 26 year old sensor probably isn't helping.
  17. Aug 20, 2022 at 11:44 AM
    #217
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Does it care how many teeth there are? Wondering if maybe its a programming thing.
  18. Aug 20, 2022 at 11:47 AM
    #218
    Speedytech7
    Yeah that's how it determines where the crank is out of 360°. Tooth 35 and 36 are missing, that's how it knows TDC. Erroring on 33 is curious to me, but I have a feeling it is a sensitivity issue considering the teeth are extremely small and a poorly functioning sensor could stop reading them accurately when the blank space is approaching, since it reads the teeth on the falling side of the sinusoidal waveform
  19. Aug 20, 2022 at 11:51 AM
    #219
    0xDEADBEEF
    Makes sense. Can you scope the sensor output itself?
  20. Aug 20, 2022 at 11:55 AM
    #220
    Speedytech7
    Actually yes, well also no. I have no idea where my Tektronix scope is. But I can scope the crank and cam sensors in the Haltech software, it'll open them up in an oscope viewer and give you all the granularity you want. Might actually be better than a real scope for this since if the haltech can't see it it doesn't matter if a good scope can.
    jubei and 0xDEADBEEF[QUOTED] like this.
