1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Oct 11, 2024 at 1:35 PM
    #2221
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You're might have drawn a good wildcard and been wired right or at least 50% right. A lot of the time the ACT still goes to an input even if they wire up AC1 right. So you can't turn the compressor off but you can at least idle up proper.
  2. Oct 11, 2024 at 1:36 PM
    #2222
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I just have the "A/C Request Switch Input" so it can do idle up. As you know my idle is pretty dialed in though, including idle up settings, so maybe that's helping
  3. Oct 11, 2024 at 1:44 PM
    #2223
    Speedytech7
    My idle is also pretty dialed, the compressor off feature isn't really for that tho, although it's nice if you're about to stall it on a rock with a manual I guess. I went back to keeping it simple, just regular ol coolant temp idle DC nums and even turned off long term trimming for idle. It just works well, thing is always where it should be these days.
    unstpible likes this.
  4. Oct 11, 2024 at 4:50 PM
    #2224
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    If I remember correctly my boomslang harness was wired correctly for the AC signal stuff but it's been to long since I looked at it to remember correctly
  5. Oct 20, 2024 at 9:02 PM
    #2225
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Was able to squeeze 14mpg out of a tank keeping hwy speeds no faster than 65mph
    TMFF likes this.
  6. Oct 20, 2024 at 9:09 PM
    #2226
    Speedytech7
    Oof, why so low?
  7. Oct 20, 2024 at 9:58 PM
    #2227
    betterbuckleup
    Ian
    Concord, CA
    Dunno. Just kinda always how it's been. Always chalked it up to being a heavy truck with 4cyl power.
    Best I got was about 16 iirc before the SC and HT with similar loadout.
  8. Oct 20, 2024 at 10:00 PM
    #2228
    Speedytech7
    Rear gears are 4.88 or 5.29?
  9. Oct 21, 2024 at 8:32 AM
    #2229
    betterbuckleup
    Ian
    Concord, CA
    4.88. Also ADD spindles with manual diff intermediate shaft, so whole front end spins all the time which doesn't help.
  10. Oct 21, 2024 at 8:33 AM
    #2230
    Speedytech7
    Ah okay, yeah I can see it then. It's tougher with 35s and 4.88, but I bet there is still a good bit left for efficiency tuning. Are you still getting detonation/ping sometimes too?
  11. Oct 21, 2024 at 8:52 AM
    #2231
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I was able to get 14/15 mpg the last few tanks after setting up the decel cut. I even went back to 14.7 target AFR in all cells besides the low load cruising area.
    And my truck is not light with the DCLB, GFC, LT, 4.88's, 34's and a manual.
  12. Oct 21, 2024 at 8:53 AM
    #2232
    Speedytech7
    What are you targeting in boost?
  13. Oct 21, 2024 at 8:55 AM
    #2233
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    12.8 up to 1psi and 12.0 past that.
  14. Oct 21, 2024 at 8:57 AM
    #2234
    Speedytech7
    If its working for you cool though, you're low boost with the newer SC right?
    TMFF[QUOTED] likes this.
  15. Oct 21, 2024 at 8:59 AM
    #2235
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Yup. I have an early TVS that can't fit smaller than a 65mm pulley without machining the snout. I will have my CNC guy machine it down sometime this winter.
  16. Oct 21, 2024 at 9:00 AM
    #2236
    Speedytech7
    Ah okay, cool. I like that SC so far for efficiency. 12.0 is probably fine low boost with that since it introduces so much less heat. We should talk about it again when you get your snout machined :)
  17. Oct 21, 2024 at 10:01 AM
    #2237
    betterbuckleup
    Ian
    Concord, CA
    no doubt there.
    I do still have to be careful with building too much boost at lower RPM's & speeds for ping. I've been procrastinating pulling the SC to move the AIT post blower. Hopefully should be able to tune most of it out at that point I'm hoping.
  18. Oct 21, 2024 at 10:06 AM
    #2238
    Speedytech7
    Probably could now, although having the sensor post boost would make it a little easier. Lemme know if you decide you want to tackle that and some efficiency stuff later on
  19. Oct 21, 2024 at 10:10 AM
    #2239
    betterbuckleup
    Ian
    Concord, CA
    Will do. I'd like to get a pod/screen to display parameters like AIT & etc as well, but the price for many of the options has been a bit prohibitive
  20. Oct 21, 2024 at 10:14 AM
    #2240
    Speedytech7
    I've been coming up with mounting ideas for those, I don't love any one location very much though. I made a set of pillar pods, those are okay just not my style, I made a single din radio set, also okay but out of sight. I am going to try a set in my center console next maybe. Tried the clock too but you know as well as i do you can't see shit there
