1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Mar 26, 2025 at 9:06 AM
    #2621
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Really should hand ballpark those regions first for safety, it's really hard for trims to get it right up there since it occurs fast and you don't necessarily dwell in the same zones long. Even just using quick tune a few times into those zones would get it closer than waiting for trims to stabilize and take you out of the possibility of danger.
    2RZNoShi1 likes this.
  2. Mar 26, 2025 at 9:37 AM
    #2622
    Speedytech7
    Can't be dialing in your VE like an art project...
  3. Mar 26, 2025 at 9:12 PM
    #2623
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
  4. Mar 26, 2025 at 9:18 PM
    #2624
    Speedytech7
  5. Mar 26, 2025 at 10:01 PM
    #2625
    2RZNoShi1
    2RZNoShi1 Well-Known Member
    Jayson
    91 SAS Pickup
    Turbo 2rz swap Haltech 750 3067 pulsar turbo 750cc injectors Solid axle swap 5.29 gears with 35's
    Came here to say the same thing... Lol the 5vz needs a bigger one, and the 2/3rz needs the 1320
    betterbuckleup likes this.
  6. Mar 26, 2025 at 10:01 PM
    #2626
    betterbuckleup
    Ian
    Concord, CA
    I wonder if there's a space constraint with the larger blower since it's on it's side sticking into the driver fender apron. Or they didn't wanna do the R&D to see if it would fit....
  7. Mar 26, 2025 at 10:11 PM
    #2627
    Speedytech7
    It's very possible, I'm sure it is still a good bit more efficient than the MP62 though. Not having an intercooler is still a tremendous oversight
  8. Mar 26, 2025 at 11:11 PM
    #2628
    betterbuckleup
    Ian
    Concord, CA
    Agreed. I still think you could squeeze one in there between the blower and manifold, but not sure how slim you can get an intercooler and how effective it would be given that constraint.
  9. Mar 27, 2025 at 11:11 AM
    #2629
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    So a quick question about Haltech Elite ECMs in general... are previous tunes lost after they are disconnected from a power source for an extended period of time?
  10. Mar 27, 2025 at 11:13 AM
    #2630
    Speedytech7
    Nope, they're stored in non volatile memory, in fact every time you turn off your truck the way they're wired they go entirely powerless
  11. Mar 28, 2025 at 5:16 AM
    #2631
    Boomtacoma01
    Houston
    I figured there had to be some sort of explanation. I appreciate the information.
    Speedytech7[OP] likes this.
  12. Mar 28, 2025 at 11:09 AM
    #2632
    Speedytech7
    No problem, I've wired too many of these things now haha. It is nice the Haltech holds on to all information written to it even without power applied, I think it would be a liability if it could randomly lose a tune. I have heard that the Nexus S/R/Rebel ECUs have a real time clock battery internally but it is just there to maintain date and time for logging purposes and if it goes bad you just lose timecodes on your logs.
  13. Mar 29, 2025 at 10:33 AM
    #2633
    betterbuckleup
    Ian
    Concord, CA
    Is there a website or place that sells OEM style plugs? Need a new cam sensor plug and would rather not go to a pick-n-pull.
  14. Mar 29, 2025 at 10:38 AM
    #2634
    Speedytech7
    Yeah, you need the weird tri lobe one right?
    https://www.rockauto.com/en/moreinfo.php?pk=13957833&cc=1317623&pt=2568&jsn=8
    There's other sites for buying oe connectors, which at least on a Toyota are mostly Denso, although there are some ones from yazaki. But they make more sense for people buying in bulk to make harnesses
  15. Mar 29, 2025 at 10:42 AM
    #2635
    Speedytech7
  16. Mar 29, 2025 at 5:11 PM
    #2636
    betterbuckleup
    Ian
    Concord, CA
  17. Mar 31, 2025 at 12:05 PM
    #2637
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    To my dismay, the new wheels & tires, about 40lbs lighter on each corner, have worsened my already bad mpg. Idk what's wrong. :annoyed: It's either gotta be bad AFR readings (maybe an exhaust leak?) and I'm running rich everywhere, and/or my timing is wildly conservative and I'm just blowing power to the wind.
    Is there anything more on the mechanical side I should check? I did a compression check a couple years ago and they were on the lower end but still acceptable. I'd assume I'd have other symptoms if that were an issue though. Everything else is in tip top shape except maybe valve lash. Could poor cam-to-crank timing cause this? I recall adjusting it back to 0* last time I had it apart, but maybe that was a mistake. Never checked with a timing light either.
  18. Mar 31, 2025 at 1:14 PM
    #2638
    betterbuckleup
    Ian
    Concord, CA
    what's your definition of bad mpg?
  19. Mar 31, 2025 at 1:16 PM
    #2639
    Speedytech7
    Exhaust isn't a bad place to start, you have a lot of places to leak or new leaks to form from cracked welds. Your O2 meets a long ways away from the action too because it is downstream of two turbos.
  20. Mar 31, 2025 at 4:29 PM
    #2640
    treyus30
    Trey
    Mesa / AJ, AZ
    On track for like 10
