1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jun 13, 2025 at 8:22 AM
    #2821
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can use a stepper output (they can function like a DPO) but you have to make sure it is set to low side control in the wiring screen. If it is set to high side it won't hurt anything but it just won't work either.
  2. Jun 13, 2025 at 8:27 AM
    #2822
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If I had my laptop with me, I could take a look. I think it is low side. However, the Passenger OCV just makes an occasional loud fast rattle/clicking noise, but very little if any phase change.
  3. Jun 13, 2025 at 8:30 AM
    #2823
    Speedytech7
    Sounds like part failure (could be the solenoid or the actual phaser unit, I know some toyota phase units leak internally when they go bad), but always worth verifying the wiring and setup first. Maybe it has bad continuity on the +12v side or something.
    Torspd[QUOTED] likes this.
  4. Jun 13, 2025 at 10:11 AM
    #2824
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The phaser itself is brand new OEM. I just installed last weekend basically. The OCV could be culprit. Since it is off of a used engine of mine.
  5. Jun 25, 2025 at 3:35 PM
    #2825
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Anyone been doing anything fun?
    I havefta not mess with the Taco too much for a few weeks since it'll be my DD once the turbo kit for my Golf comes in.
  6. Jun 25, 2025 at 8:35 PM
    #2826
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    Been playing around with blending speed density and MAF fueling. No real reason, just kinda tinkering right now. At idle it’s 100% SD. As load increases it starts blending more and more input from the MAF, and then at high load it’s 100% MAF.
    That’s just for the calculation of how much air the engine is consuming. AFR targets are still set off of MAP vs RPM.
    treyus30[QUOTED] likes this.
  7. Jun 25, 2025 at 9:37 PM
    #2827
    treyus30
    Trey
    Mesa / AJ, AZ
    Odd... What's the benefit?
    Speedytech7[OP] likes this.
  8. Jun 26, 2025 at 1:57 PM
    #2828
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    More precise air metering via the MAF than with SD. MAF is measuring the air consumption is real time while SD is calculations based on your VE table to infer how much air the engine is consuming. And engine mods (opening up exhaust more, etc.) throw off the VE table needing a re-tune. MAF tuning isn't as sensitive to VE changes or elevation changes as SD since it's measuring the airflow directly. MAF-only tuning took a lot of smoothing of the MAF signal due to how choppy of a signal it is. But now it can run SD, MAF, or a blend of the two. Really I wanted to get the engine running on both strategies, and when I did I decided to play around with blending them. SD isn't really affected by any small vacuum leaks, as the MAP picks up the change in manifold pressure and adjusts accordingly. With MAF-only that vacuum leak is is bypassing the MAF throwing off fueling completely. Kinda sucked when I was on the stock ECU (that's MAF-only) and I blew off a vacuum hose on the freeway, and was running real lean in downtown traffic stop-n-go traffic. By playing around with blending I figured I'd see if I could get the best of both worlds. Dunno if I'll keep it this way or not yet, just playing with it.
    I also finally got around to wiring up my flex fuel sensor that I've had plumbed into the fuel return line. So going to start playing with E85 too.
    Torspd likes this.
  9. Jun 26, 2025 at 2:32 PM
    #2829
    treyus30
    Trey
    Mesa / AJ, AZ
    In my experience, both can have issues when running low airflow. It just comes with the territory of less room for error, more noise.
    I guess if you're planning on doing a lot of changes still it makes sense, but VE is simply a calculation of fuel error at a given RPM (velocity) and manifold pressure (together they make mass with a known density), so they're basically doing the same thing. MAF is just the absolute reading, hence why we still use fuel trims for both. As you say, SD is impervious to leaks pre-throttle, and I've already gained the benefit of that myself when the intake tube blew off in the middle of a drive.
    Idk, I've argued the benefit of a MAF system for modern vehicles, but it takes a completely different premise which is that they use torque request via an e-throttle pedal and have tables for what MAF will result in that request. To know that, you have to map out the turbo flow rate: pressure (compressor map), what duty cycle the wastegate needs at each point to reach the desired flow, and some other ancillaries. The MAF is a lot more important in this circumstance because it's ultimately the failsafe check that everything else is running as expected. But you get the benefit of mapping your foot to actual torque instead of a % throttle at the end.
  10. Jun 26, 2025 at 7:25 PM
    #2830
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    VE is a measure of how well the engine fills the cylinders with air, compared to its theoretical max. VE changes as the engine ages and wears, or like many drivers, due to lack of maintenance. VE then decreases. Conversely, VE changes if say you install a freer flowing exhaust or get heads that flow better. Then VE increases. Speed density relies on having an accurate VE table so that it can accurately calculate how much air is being consumed. MAF doesn’t rely on VE table.
    Pros and cons to both, and I’m not married to either. I had the MAF in place already from when the stock ECU was controlling things, so I figured I’d give it a go. It runs fine on either fueling strategy.
  11. Jun 27, 2025 at 2:26 PM
    #2831
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Recently took a 1500mile road trip and got the best gas mileage I've ever seen at a whopping 17.3mpg while going through Yosemite. Average for the entire trip was right at about 16
  12. Jun 30, 2025 at 7:03 AM
    #2832
    Speedytech7
    This is part of the reason ITB setups (even ones with a plenum ahead of the ITBs) often run alpha-n in idle and super low load. It's a common enough issue that HP academy and Haltech have articles for tuning stock RB26s that still have their ITBs in place. If it is just causing trims to move a bit at idle but the driving/idling behavior is okay you probably don't need to employ a second metering strategy through. It is when the engine is modified (usually cams) that they can behave pretty poorly and you need to intervene with a second metering strategy.
    Torspd likes this.
  13. Jul 14, 2025 at 7:05 PM
    #2833
    Boomtacoma01
    Boomtacoma01 Well-Known Member
    Houston
    Has anyone found a weatherproof/waterproof enclosure for an IC7 or potentially designed one?
  14. Jul 14, 2025 at 11:18 PM
    #2834
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is it for the buggy?
    I'm using a Mako Motorsports dash insert for my ic7. Not sure how waterproof it is. But then, for my my situation it doesn't need to be. It is a 3D printed setup.
    They make quite a variety of mounts for Haltech dashes. Maybe they make one that would work for your situation.
    https://makomotorsport.com/products...GNb3zX1hjEN_RuZuHKapbcXOfPJ2cz7hCRJYZe2Bd2uuR
  15. Jul 15, 2025 at 3:02 PM
    #2835
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    @treyus30 any updates on your HT compatible open source CAN gauge project with display sizes?
    The MAP sensor on my Innovate PSB1 took a shit the other weekend so I'm learning towards putting together one in it's place instead of spending $70 on another innovate sensor.
  16. Jul 15, 2025 at 3:27 PM
    #2836
    Speedytech7
    They work just fine. We've installed them in other stuff. The link to it is in his signature, you just have to build it. I can get you a parts list of the ones I use to make standard 2-in gauges
  17. Jul 15, 2025 at 4:20 PM
    #2837
    betterbuckleup
    Ian
    Concord, CA
    Parts list would be great if you have it.
    I was planning to model up and 3d print an enclosure for the whole thing to fit in my clock space.
    2RZNoShi1 likes this.
  18. Jul 17, 2025 at 3:35 PM
    #2838
    Boomtacoma01
    Houston
    Yeah its for the buggy, had a buddy fry his IC7 after it got rained on. Thought it would be better to prepare for it now rather than later..
    Appreciate the link.
  19. Jul 18, 2025 at 6:55 AM
    #2839
    Speedytech7
    Sure, depending on how many displays you want at a given time... you either need 1 SSD1309 SPI display or however many SSD1306 SPI displays you can fit in the clock area... maybe 2 or 3. An arduino nano (or clone), might I suggest one with USB C. Then you need a MCP2515 CAN module... and finally some twisted pair wiring to hook it all up(I use some from ethernet cables usually). Oh and a DTM06-4S (female) connector to hook to the can connection on your haltech
  20. Jul 18, 2025 at 11:54 AM
    #2840
    betterbuckleup
    Ian
    Concord, CA
    Sweet thanks.
    Do you have any pictures of the setups you put together with this system?
